接上:
CRC-ITU的验证算法如下:
a.寄存器组初始化为全"1"(0xFFFF)。
b.寄存器组向右移动一个字节。
c.刚移出的那个字节与数据字节进行异或运算,得出一个指向值表的索引。
d.索引所指的表值与寄存器组做异或运算。
e.数据指针加1,如果数据没有全部处理完,则重复步骤b (数据包括CRC的两个字节)。
f.寄存器组的值是否等于“Magic Value”(0xF0B8),若相等则通过,否则失败。
下面是通用的CRC-ITU查找表以及计算和验证CRC的C语言程序:
// CRC-ITU查找表
const u16 crctab16[] =
0x0000, 0x1189, 0x2312, 0x329b, 0x4624, 0x57ad, 0x6536, 0x74bf,
0x8c48, 0x9dc1, 0xaf5a, 0xbed3, 0xca6c, 0xdbe5, 0xe97e, 0xf8f7,
0x1081, 0x0108, 0x3393, 0x221a, 0x56a5, 0x472c, 0x75b7, 0x643e,
0x9cc9, 0x8d40, 0xbfdb, 0xae52, 0xdaed, 0xcb64, 0xf9ff, 0xe876,
0x2102, 0x308b, 0x0210, 0x1399, 0x6726, 0x76af, 0x4434, 0x55bd,
0xad4a, 0xbcc3, 0x8e58, 0x9fd1, 0xeb6e, 0xfae7, 0xc87c, 0xd9f5,
0x3183, 0x200a, 0x1291, 0x0318, 0x77a7, 0x662e, 0x54b5, 0x453c,
0xbdcb, 0xac42, 0x9ed9, 0x8f50, 0xfbef, 0xea66, 0xd8fd, 0xc974,
0x4204, 0x538d, 0x6116, 0x709f, 0x0420, 0x15a9, 0x2732, 0x36bb,
0xce4c, 0xdfc5, 0xed5e, 0xfcd7, 0x8868, 0x99e1, 0xab7a, 0xbaf3,
0x5285, 0x430c, 0x7197, 0x601e, 0x14a1, 0x0528, 0x37b3, 0x263a,
0xdecd, 0xcf44, 0xfddf, 0xec56, 0x98e9, 0x8960, 0xbbfb, 0xaa72,
0x6306, 0x728f, 0x4014, 0x519d, 0x2522, 0x34ab, 0x0630, 0x17b9,
0xef4e, 0xfec7, 0xcc5c, 0xddd5, 0xa96a, 0xb8e3, 0x8a78, 0x9bf1,
0x7387, 0x620e, 0x5095, 0x411c, 0x35a3, 0x242a, 0x16b1, 0x0738,
0xffcf, 0xee46, 0xdcdd, 0xcd54, 0xb9eb, 0xa862, 0x9af9, 0x8b70,
0x8408, 0x9581, 0xa71a, 0xb693, 0xc22c, 0xd3a5, 0xe13e, 0xf0b7,
0x0840, 0x19c9, 0x2b52, 0x3adb, 0x4e64, 0x5fed, 0x6d76, 0x7cff,
0x9489, 0x8500, 0xb79b, 0xa612, 0xd2ad, 0xc324, 0xf1bf, 0xe036,
0x18c1, 0x0948, 0x3bd3, 0x2a5a, 0x5ee5, 0x4f6c, 0x7df7, 0x6c7e,
0xa50a, 0xb483, 0x8618, 0x9791, 0xe32e, 0xf2a7, 0xc03c, 0xd1b5,
0x2942, 0x38cb, 0x0a50, 0x1bd9, 0x6f66, 0x7eef, 0x4c74, 0x5dfd,
0xb58b, 0xa402, 0x9699, 0x8710, 0xf3af, 0xe226, 0xd0bd, 0xc134,
0x39c3, 0x284a, 0x1ad1, 0x0b58, 0x7fe7, 0x6e6e, 0x5cf5, 0x4d7c,
0xc60c, 0xd785, 0xe51e, 0xf497, 0x8028, 0x91a1, 0xa33a, 0xb2b3,
0x4a44, 0x5bcd, 0x6956, 0x78df, 0x0c60, 0x1de9, 0x2f72, 0x3efb,
0xd68d, 0xc704, 0xf59f, 0xe416, 0x90a9, 0x8120, 0xb3bb, 0xa232,
0x5ac5, 0x4b4c, 0x79d7, 0x685e, 0x1ce1, 0x0d68, 0x3ff3, 0x2e7a,
0xe70e, 0xf687, 0xc41c, 0xd595, 0xa12a, 0xb0a3, 0x8238, 0x93b1,
0x6b46, 0x7acf, 0x4854, 0x59dd, 0x2d62, 0x3ceb, 0x0e70, 0x1ff9,
0xf78f, 0xe606, 0xd49d, 0xc514, 0xb1ab, 0xa022, 0x92b9, 0x8330,
0x7bc7, 0x6a4e, 0x58d5, 0x495c, 0x3de3, 0x2c6a, 0x1ef1, 0x0f78,
// 计算给定长度数据的16位CRC。
u16 GetCrc16(const byte* pData, int nLength)
u16 fcs = 0xffff; // 初始化
while(nLength>0)
fcs = (fcs >> 8) ^ crctab16[(fcs ^ *pData) & 0xff];
nLength--;
pData++;
return ~fcs; // 取反
// 检查给定长度数据的16位CRC是否正确。
bool IsCrc16Good(const byte* pData, int nLength)
while(nLength>0)
nLength--;
pData++;
return (fcs == 0xf0b8); // 0xf0b8是CRC-ITU的"Magic Value"
使用字节型算法,前面出现的PPP帧FCS计算和验证过程,可用下面的程序片断实现:
byte ppp[13] = {0xFF, 0x03, 0xC0, 0x21, 0x04, 0x03, 0x00, 0x07, 0x0D, 0x03, 0x06, 0x00, 0x00};
u16 result;
// 计算CRC
result = GetCrc16(ppp, 11);
// 填写FCS,先低后高
ppp[11] = result & 0xff;
ppp[12] = (result >> 8) & 0xff;
// 验证FCS
if(IsCrc16Good(ppp, 13))
该例中数据长度为11,说明CRC计算并不要求数据2字节或4字节对齐。
至于查找表的生成算法,以及CRC-32等其它CRC的算法,可参考RFC 1661, RFC 3309等文档。需要注意的是,虽然CRC算法的本质是一样的,但不同的协议、标准所规定的初始化、移位次序、验证方法等可能有所差别。
结语
CRC是现代通信领域的重要技术之一。掌握CRC的算法与实现方法,在通信系统的设计、通信协议的分析以及软件保护等诸多方面,能发挥很大的作用。如在作者曾经设计的一个多串口数据传输系统中,每串口速率为460kbps,不加校验时误码率大于10-6,加上简单的奇偶校验后性能改善不很明显,利用CRC进行检错重传,误码率降低至10-15以下,满足了实际应用的要求。 |
