代码如下,各位大虾给看看,用示波器测试PWM0口没有反映,到底怎么回事
#include <hidef.h> /* common defines and macros */ #include <mc9s12dg128.h> /* derivative information */
#pragma LINK_INFO DERIVATIVE "mc9s12dg128b"
#define PWCLK_ (*((volatile unsigned char*)(0x0040))) #define PWPOL_ (*((volatile unsigned char*)(0x0041))) #define PWEN_ (*((volatile unsigned char*)(0x0042))) #define PWSCAL0_ (*((volatile unsigned char*)(0x0044))) #define PWCNT0_ (*((volatile unsigned char*)(0x0048))) #define PWPER0_ (*((volatile unsigned char*)(0x004c))) #define PWDTY0_ (*((volatile unsigned char*)(0x0050))) #define PWCTL_ (*((volatile unsigned char*)(0x0054))) #define PORTP_ (*((volatile unsigned char*)(0x0056)))
void main(void) { /* put your own code here */ EnableInterrupts; PWCLK_ = 0x18; //通道分用A口32分频 PWPOL_ = 0x11; //用s0口做0通道的时钟 先高电平 PWSCAL0_ = 4; //s0口提供10kHz的频率 PWPER0_ = 99; //舵机的频率是100Hz PWCNT0_ = 100; DDRP = 0xff; //控制输出,此行有没有都结果 PWDTY0_ = 49; PWEN_ = 0x01;
for(;;) {} /* wait forever */ } |
