原文如下
This is a quick reference for using the analog-to-digital converter (ATD) module on an HCS08 microcontroller (MCU). The ATD module is different from the ADC module — check the data sheet for your device. Basic information about the functional description and configuration options is provided. The following
examples may be modified to suit your application — again, refer to the data sheet for your device.
主要增加了一个检查设备数据的功能。 |
