我的9S12DG128MPV新做的试制板,第二块板仿真器能识别芯片,但是在COMMAND窗口看到的芯片总线速度为1.2MHZ,实际我使用的是16MHZ有源晶振,示波器测量频率很准!
请教各位这是什么原因?通过串口初始化的发送速度,也证明总线速度不为8MHZ.另芯片是用手工焊的,效果很差!下面是COMMAND中的相关信息:
Reset command file correctly executed.
FP: FLASH parameters loaded for MC9S12DG128B_V11(NVMIF2) from D:\Program Files\Freescale\CW for HC12 V4.5\prog\FPP\mcu03DC.fpp
MCU clock speed: 1297000 Hz
Block Module Name Address Range Status
0 EEPROM 2000 - 27FF Blank - Unselected
1 FLASH_4000 4000 - 7FFF Blank - Unselected
2 FLASH_C000 C000 - FFFF Programmed - Unselected
3 ALL_PPAGES 388000 -3FBFFF Programmed - Unselected
4 FLAT8000_P38 8000 - BFFF Programmed - Unselected
FP: The UNPROTECT command is not available for the EEPROM flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
FP: The UNPROTECT command is not available for the ALL_PPAGES flash module => Skipped.
FP: The UNPROTECT command is not available for the FLAT8000_P38 flash module => Skipped.
executing .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
Vppon command file correctly executed.
executing .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
Vppoff command file correctly executed.
FP: Arm FLASH for loading.
FP: FLASH disarmed.
executing .\cmd\P&E_Multilink_CyclonePro_reset.cmd
!// After reset the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_reset.cmd
executing .\cmd\P&E_Multilink_CyclonePro_postload.cmd
!// After load the commands written below will be executed
RESET
done .\cmd\P&E_Multilink_CyclonePro_postload.cmd
Postload command file correctly executed.
STARTED
RUNNING
Breakpoint
in> |
