[求助]PE生成的读写EEPROM的程序为什么总是跑飞?
![Rank: 2](images/default/star_level2.gif)
在main函数中循环调用EEP_SetActByte(data);写入字符串
用BDM调试发现总是在写入第2个字节时,执行modify sector操作的时候跑飞
另外用pe有点不清楚的地方是cpu的那一栏属性里工作模式应该选special single
还是 normal single ?接下来还有调整模式的选项都不知道应该怎样选。。。
下面是主函数部分的代码
** Filename : eepromtest.C
** Project : eepromtest
** Processor : MC9S12DG128BCPV
** Version : Driver 01.11
** Compiler : Metrowerks HC12 C Compiler
** Date/Time : 2007-5-28, 19:59
** Abstract :
** Main module.
** Here is to be placed user's code.
** Settings :
** Contents :
** No public methods
** (c) Copyright UNIS, spol. s r.o. 1997-2005
** UNIS, spol. s r.o.
** Jundrovska 33
** 624 00 Brno
** Czech Republic
** http : www.processorexpert.com
** mail : info@processorexpert.com
/* MODULE eepromtest */
/* Including used modules for compiling procedure */
#include "Cpu.h"
#include "EEP.h"
/* Include shared modules, which are used for whole project */
#include "PE_Types.h"
#include "PE_Error.h"
#include "PE_Const.h"
#include "IO_Map.h"
const char s[20]="SaserKing";
volatile char a[20]={0};
volatile char b[20]={0};
void main(void)
unsigned int i;
unsigned int j;
/*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
PE_low_level_init();
/*** End of Processor Expert internal initialization. ***/
__DI();
i=0;
while (s!=0) {
EEP_SetActByte(s);
i++;
EEP_SetActByte(0);
i=EEPROMStart;
while((*(char*)i) != 0)
a[i-EEPROMStart]=*(char*)i;
i++;
j=0;
while (s[j]!=0) {
EEP_SetByte(i,s[j]);
j++;
i++;
EEP_SetActByte(0);
i=EEPROMStart;
while((*(char*)i) != 0) {
b[i-EEPROMStart]=*(char*)i;
i++;
/* Write your code here */
/*** Processor Expert end of main routine. DON'T MODIFY THIS CODE!!! ***/
for(;;){}
/*** Processor Expert end of main routine. DON'T WRITE CODE BELOW!!! ***/
} /*** End of main routine. DO NOT MODIFY THIS TEXT!!! ***/
/* END eepromtest */
** This file was created by UNIS Processor Expert 2.96 [03.76]
** for the Freescale HCS12 series of microcontrollers.
关闭pll busclk=8M时正常
打开pll busclk-24M就跑飞
EEPROM会受pll影响么? |
EEPROM的时钟必须设置在150K~200KHz之间。 |
刚解决 3x
是开发板供电不稳的问题,所有程序都飞,和eeprom无关
pe果然好用 |
