;SwPort: equ PTQ ;pushbutton sw connected to port Q
;Switch: equ PTQ0 ;switch connected to PTQ bit-5
;SwPullup: equ PERQ ;pullup enable for sw port
;mSwPullup: equ PTQ0 ;Mask value to enable for sw port
;SwPort: equ PTP ;pushbutton sw connected to port P
;Switch: equ PTP5 ;switch connected to PTP bit-5
;SwPullup: equ PERP ;pullup enable for sw port
;mSwPullup: equ PTP5 ;Mask value to enable for sw port
SwPort: equ PORTA ;pushbutton sw connected to port A
Switch: equ PTA6 ;switch connected to PTA bit-6
SwPullup: equ PUCR ;pullup enable for sw port
mSwPullup: equ PUPAE ;Mask value to enable for sw port
;SwPort: equ PORTB ;pushbutton sw connected to port B
;Switch: equ PTB4 ;switch connected to PTB bit-4
;Switch: equ PTB0 ;switch connected to PTB bit-0
;SwPullup: equ PUCR ;pullup enable for sw port
;mSwPullup: equ PUPBE ;Mask value to enable for sw port
;SwPort: equ PTL ;pushbutton sw connected to port P
;Switch: equ PTL6 ;switch connected to PTP bit-5
;SwPullup: equ PERL ;pullup enable for sw port
;mSwPullup: equ PTL6 ;Mask value to enable for sw port
;Switch: equ PTP0 ;switch connected to PTP bit-0
;mSwPullup: equ PTP0 ;Mask value to enable for sw port
;SwPort: equ PTG ;pushbutton sw connected to port G
;Switch: equ PTG4 ;switch connected to PTP bit-4
;SwPullup: equ PERG ;pullup enable for sw port
;mSwPullup: equ PTG4 ;Mask value to enable for sw port
