#include #include #include #include #include #define LPT_PORT 0x378 #define CLR_WCK(X) {X=X&(~(1<<0)); outportb(LPT_PORT,X); } // data.0 #define SET_WCK(X) {X=X | (1<<0) ; outportb(LPT_PORT,X); } #define CLR_BCK(X) {X=X&(~(1<<2)); outportb(LPT_PORT,X); } // data.2 #define SET_BCK(X) {X=X | (1<<2) ; outportb(LPT_PORT,X); } #define CLR_DATA(X) {X=X&(~(1<<3)); outportb(LPT_PORT,X); } // data.3 #define SET_DATA(X) {X=X | (1<<3) ; outportb(LPT_PORT,X); } #define FALSE 0 #define TRUE 1 void test_comm() { unsigned char data ; data = 0; printf("Please press enter to begin send data\n"); getch(); printf("Pull down WCK data.0\n"); CLR_WCK(data); getch(); printf("Pull up WCK data.0\n"); SET_WCK(data); getch();
printf("Pull down BCK data.2\n"); CLR_BCK(data); getch(); printf("Pull up BCK data.2\n"); SET_BCK(data); getch();
printf("Pull down DATA data.3\n"); CLR_DATA(data); getch(); printf("Pull up DATA data.3\n"); SET_DATA(data); getch(); } // Note: the size of buffer to send must be dword multiple // size is the number of bytes to send void short_delay(int n) { int i; for(i=0;i {int temp =0;} } int send_spi_data(unsigned char *buffer, unsigned long size) { unsigned char buff[1024]; unsigned char *buf=buff; unsigned char data; int i,j,k; data =0; if((size%4)!=0) return FALSE; memcpy(buff,buffer,size);
do{ SET_WCK(data); for(k=0;k<2;k++){ for(j=0;j<2;j++){ printf("."); for(i=0;i<8;i++){ if((*buf)&0x80){ SET_DATA(data); }else{ CLR_DATA(data); } short_delay(1); // delay(1); SET_BCK(data); short_delay(1); // delay(1); CLR_BCK(data); short_delay(1); // delay(1); *buf<<=1; } buf++; size--; } // buf++; // size--; CLR_WCK(data); } SET_WCK(data); }while(size>0); return TRUE; } /* void main() { int i; unsigned char tmpdata[4]; tmpdata[0] = 0x34; tmpdata[1] = 0x12; tmpdata[2] = 0x56; tmpdata[3] = 0x78; // for(i=0;i<500;i++) for(i=0;i<50;i++) { send_spi_data(tmpdata,4); }
// test_comm(); } */ |
