#!/bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. # cd D:/niosworks/hello/software/hello_led_1/Debug # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x01800000 --end=0x1ffffff --reset=0x1800 000 --input="hello_led_1.elf" --output="cfi_flash.flash" --boot="D:/altera/71/ip /nios2_ip/altera_nios2/boot_loader_cfi.srec" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x01800000 --sidp=0x02003038 --id=1163126162 --timestamp=1212541811 --instance=0 "cfi_flash.flash" Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x02003038: verified : Checksumming existing contents 00000000 : Reading existing contents Checksummed/read 128kB in 2.5s 00000000 ( 0%): Erasing Erased 128kB in 0.6s (213.3kB/s) 00000000 ( 0%): Programming Programmed 1KB +127KB in 3.0s (42.6KB/s) Verify failed at offset 0 Leaving target processor paused 哪位大侠帮帮我啊! |
