一个很简单的程序,是关于字符串操作的,就是几行代码,程序如下: module string; reg[8*14:1] stringvar; initial begin stringvar="Hello world"; $display("%s is stored as %h",stringvar,stringvar); stringvar={stringvar,"!!!"}; $display("%s is stored as %h",stringvar,stringvar); end endmodule 运行的时候报错,错误如下: # ** Error: (vlog-7) Failed to open file "string/string/_primary.vhd" in w+b mode. # No such file or directory. (errno = ENOENT) # ** Error: (vlog-7) Failed to open library file "string/string/_primary.vhd" in write mode. # No such file or directory. (errno = ENOENT) # ** Error: E:/Modeltech_5.7e/examples/string/string.v(10): Verilog Compiler exiting 我用的是modelsim,好像说打开文件失败,麻烦各位帮忙看看,先谢谢了 |
