请高手帮忙,我用Verilog写了一个LCD的驱动,用状态机写的,但编译的时候有很多警告。请高手指点,初学中。。。所有变量都定义为reg always @(posedge clkdiv,negedge reset) begin if(!reset) current_state<=st0; else current_state<=next_state; end always @(current_state,lcd_busy) begin case(current_state) st0: //initial begin lcd_req=1'b0; cnt_a=2'b00; cnt_d=2'b00; addr_a=5'd0; addr_d=6'd0; data_all=0; f0=1'b0; next_state<=st1; end
st1: begin next_state<=st2; end
st2: //LCD is busy? yes wait.else put the data on the data_bus begin if(lcd_busy==1'b1) next_state<=st2; else next_state<=st3; end
st3: begin if(!f0) //writing f0 begin lcd_data=8'hf0; f0=1'b1; next_state<=st6; end else begin next_state<=st4; end end
st4://write x\y axis begin if(cnt_a<2'd2) begin lcd_data=axis(addr_a); addr_a=addr_a+5'd1; cnt_a=cnt_a+2'd1; next_state<=st6; end else next_state<=st5; end
st5: //write data begin if(cnt_d<2'd2) begin lcd_data<=data_ram(addr_d); addr_d=addr_d+6'd1; cnt_d=cnt_d+2'd1; end else //finishing writing one chinese word begin data_all=data_all+1; cnt_d=2'd0; cnt_a=2'd0; f0=1'b0; end next_state<=st6; end
st6: //request LCD processing begin lcd_rea=1'b1; next_state<=st7; end
st7: //waiting data is dealt with begin if(lcd_busy==1'b0) next_state<=st7; else next_state<=st8; end
st8: //withdrawing requesting_signal begin if(data_all<DANUM) //write next data next_state<=st2; else next_state<=st0; end
default: next_state<=st0;
endcase end 整个程序的任务是完成LCD显示汉字,为了显示汉字要先向LCD里写F0,X、Y坐标,最后送入汉字的区码、位码。每次向LCD发送写指令时要先判断LCD是否忙(lcd_busy==1?)不忙时(lcd_busy==0)将数据送到数据线上,下一步是请求LCD处理(令lcd_req=1),再次判断(lcd_busy==1?)如果是则表明LCD处于数据处理状态此时可令lcd_req=0,以撤消请求。这样就完成了一次LCD数据写操作。 我在学程序的时候严格按照步骤来的,但编译出来总是提示好多错误,并且仿真得不到结果,像提示 cnt_a,cnt_d addr_a,addr_d,data_all,f0这些变量有不安全行为,并产生了Latch,还说在Always里面读了但没放到信号列表里,还有通过很多的途径张变了这些变量的值。 希望哪位高人能提出些建议,先谢谢各位! |
