LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; --USE WORK.my_pkg.ALL; ENTITY clkgen IS PORT(sysres,en1,clk:IN STD_ULOGIC; cntclk,keyclk:OUT STD_ULOGIC); END clkgen; ARCHITECTURE rtl OF clkgen IS COMPONENT cnt10
PORT(reset,en,clk:IN STD_ULOGIC; carry:OUT STD_ULOGIC; q:OUT STD_ULOGIC_VECTOR(3 DOWNTO 0)); END COMPONENT ; COMPONENT cnt4 PORT(reset,en,clk:IN STD_ULOGIC; carry:OUT STD_ULOGIC; q:OUT STD_ULOGIC_VECTOR(1 DOWNTO 0)); END COMPONENT; SIGNAL cntclk_S:STD_ULOGIC; BEGIN u0:cnt10 PORT MAP(sysres,en1,clk,cntclk_s); u1:cnt4 PORT MAP(sysres,cntclk_s,clk,keyclk); cntclk<=cntclk_s; END rtl; 红色处报错:Unsupported feature error:Enumeration Type Definition not supported in Port Declaration of the Component Instantion Statement 请大侠们指点下,感激不尽 |
