我想获取TCNT溢出中断的个数,该从哪里看呢?我用的是CW4.7 的PE Well, I would use something like input capture method. The idea is: - enable the free running timer (TIM) - at the start save the current value of timer count register TCNT (first_value) - enable the timer overflow interrupt - count the overflow interrupts (overflows++) - at the end save the current value of TCNT (second_value) - now calculate the interval: (0x10000 - first_value) + (overflows * 0x10000) + second_value If the timer didn't overflow then it's simple: second_value - first_value It will be necessary to find out appropriate timer prescaler (I don't know what intervals you want to measure). In fact, this method can be used also for ISR's length measuring. But there's problem with the timer overflow interrupt as I wrote in my previous reply. If the length of ISR is not greater than the period between two overflows then I can imagine this method:
interrupt void test(void) {
TFLG2_TOF = 1;
//clear timer overflow flag (interrupt is disabled) first_value = TCNT;
//do something here
second_value = TCNT;
if(TFLG2_TOF == 1)
length = 0x10000 - first_value + second_value;
else
length = second_value - first_value }
