9s12xdt256芯片烧写问题
9s12xdt256芯片烧写问题
你好,support
我们使用的xdt256开发板的时候,有两个批次的芯片安装在我们的开发板上。其中MC9S12XDT256MAL 0L15L QQDX0721整个批次的芯片贴了两块都是出现了问题,无论是用什么晶振都没有办法正常烧写。MC9S12XDT256MAL 1M84E QQCW0830批次的没有问题。请问这是什么原因导致的??
出现问题时候会弹出如下框
Error while writing to FFFE..101FE (附件里面有图片)
并且在command对话框中出现
executing C_layout.hwl
!OPEN source 0 0 60 39
NO CONNECTION
!Source < attributes MARKS off
!OPEN assembly 60 0 40 31
!Assembly < attributes ADR on,CODE off,ABSADR on,SYMB off,TOPPC 0xF88C
!OPEN procedure 0 39 60 17
!Procedure < attributes VALUES on,TYPES off
!OPEN register 60 31 40 25
!Register < attributes FORMAT AUTO,COMPLEMENT None
!OPEN memory 60 56 40 22
!Memory < attributes FORMAT hex,COMPLEMENT None,WORD 1,ASC on,ADR on,ADDRESS 0x80
!OPEN data 0 56 60 22
!Data:1 < attributes SCOPE global,COMPLEMENT None,FORMAT Symb,MODE automatic,UPDATERATE 10,NAMEWIDTH 16
!OPEN data 0 78 60 22
!Data:2 < attributes SCOPE local,COMPLEMENT None,FORMAT Symb,MODE automatic,UPDATERATE 10,NAMEWIDTH 16
!OPEN command 60 78 40 22
!Command < attributes CACHESIZE 1000
!bckcolor 50331647
!font 'Courier New' 9 BLACK
!AUTOSIZE on
!ACTIVATE Data:2 Command Procedure Data:1 Source Register Assembly Memory
done C_layout.hwl
Loading Target ...
SETCOMM DRIVER NOPROTOCOL NOPERIODICAL ""
SETCOMM COMPORT NONE
IO registers loaded for MC9S12XDT256 from D:\FreescaleCW47\prog\REG\MCU02C7.REG
executing .\cmd\P&E_Multilink_CyclonePro_startup.cmd
!// At startup the commands written below will be executed
Target Ready
done .\cmd\P&E_Multilink_CyclonePro_startup.cmd
Startup command file correctly executed.
executing .\cmd\P&E_Multilink_CyclonePro_preload.cmd
!// Before load the commands written below will be executed
Target Ready
done .\cmd\P&E_Multilink_CyclonePro_preload.cmd
Preload command file correctly executed.
executing .\cmd\P&E_Multilink_CyclonePro_reset.cmd
!// After reset the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_reset.cmd
Reset command file correctly executed.
FP: FLASH parameters loaded for MC9S12XDT256_V10(NVMIF2 rev 2,2,2,2,1,1,1,1) from D:\FreescaleCW47\prog\FPP\mcu02C7.fpp
MCU clock speed: 1431000 Hz
Block Module Name Address Range Status
0 FLASH_4000 4000 - 7FFF Blank - Unselected
1 FLASH_C000 C000 - FFFF Blank - Unselected
2 PAGES_E0_E7 E08000 -E7BFFF Programmed - Unselected
3 PAGES_F8_FF F88000 -FFBFFF Programmed - Unselected
4 EEPROM_C00 C00 - FFF Blank - Unselected
5 ALL_EPAGES FC0800 -FF0BFF Blank - Unselected
6 EEPROM_800 800 - BFF Blank - Unselected
7 FLASH_8000 8000 - BFFF Blank - Unselected
FP: The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
FP: The UNPROTECT command is not available for the PAGES_E0_E7 flash module => Skipped.
FP: The UNPROTECT command is not available for the PAGES_F8_FF flash module => Skipped.
FP: The UNPROTECT command is not available for the EEPROM_C00 flash module => Skipped.
FP: The UNPROTECT command is not available for the ALL_EPAGES flash module => Skipped.
FP: The UNPROTECT command is not available for the EEPROM_800 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_8000 flash module => Skipped.
executing .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
Vppon command file correctly executed.
FP: Operation failed on FLASH_4000 flash module.
FP: Operation failed on FLASH_C000 flash module.
FP: Operation failed on PAGES_E0_E7 flash module.
FP: Operation failed on PAGES_F8_FF flash module.
FP: Operation failed on EEPROM_C00 flash module.
FP: Operation failed on ALL_EPAGES flash module.
FP: Operation failed on EEPROM_800 flash module.
FP: Operation failed on FLASH_8000 flash module.
executing .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
Vppoff command file correctly executed.
FP: Arm FLASH for loading.
FP: FLASH disarmed.
executing .\cmd\P&E_Multilink_CyclonePro_postload.cmd
!// After load the commands written below will be executed
RESET
done .\cmd\P&E_Multilink_CyclonePro_postload.cmd
Postload command file correctly executed.
in>
看的眼晕 版主看看怎么回事啊 我也不懂
睡觉睡到自然醒,数钱数到手抽筋!
    ╭╯G O ╠╣支持楼主╠╣正真牛人 ╠╣雁过留声╠╣人过留帖╠╣拿分走人╣
