[求助]如何将Modelsim仿真数据保存为txt格式?
请问各位大侠怎么将Modelsim仿真数据保存为txt格式?
我做了一个DDS,把12bit二进制表示的正弦值(DDS_Out)输出到d:\out_file.txt文件中,主要是仿真时(我是直接用ISE中的仿真,与Modelsim仿真互通)把仿真结果输出到文件中就可以了。仿真程序参考如下。
[此贴子已经被作者于2009-5-22 9:39:27编辑过]
-- Company:
-- Engineer:
-- Create Date: 11:17:12 04/13/2009
-- Design Name: DDFS
-- Module Name: D:/vhdl/dds1/out_txt.vhd
-- Project Name: dds1
-- Target Device:
-- Tool versions:
-- Description:
-- VHDL Test Bench Created by ISE for module: DDFS
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
-- Notes:
-- This testbench has been automatically generated using types std_logic and
-- std_logic_vector for the ports of the unit under test. Xilinx recommends
-- that these types always be used for the top-level I/O of a design in order
-- to guarantee that the testbench will bind correctly to the post-implementation
-- simulation model.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
library STD;
use STD.TEXTIO.ALL;
ENTITY out_txt_vhd IS
END out_txt_vhd;
ARCHITECTURE behavior OF out_txt_vhd IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT DDFS
PORT(
CLK : IN std_logic;
reset : IN std_logic;
Freq_Data : IN std_logic_vector(13 downto 0);
Dout : OUT std_logic_vector(14 downto 0);
Dac_clk : OUT std_logic
END COMPONENT;
--Inputs
SIGNAL CLK : std_logic := '0';
SIGNAL reset : std_logic := '0';
SIGNAL Freq_Data : std_logic_vector(13 downto 0) := "00011110101110";--(others=>'0');
-- 32109876543210
--Outputs
SIGNAL DDS_Out : std_logic_vector(14 downto 0);
SIGNAL Dac_clk : std_logic;
file out_file:text is out "d:\out_file.txt";
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: DDFS PORT MAP(
CLK => CLK,
reset => reset,
Freq_Data => Freq_Data,
Dout => DDS_Out,
Dac_clk => Dac_clk
clk<=not clk after 0.5ns; --100Mhz
tb : PROCESS
BEGIN
reset<='0';
wait for 0.1 ns; -- Wait 20 ns for global reset to finish
reset<='1';
-- Place stimulus here
wait; -- will wait forever
END PROCESS;
PROCESS(DDS_Out)
variable out_line:line;
begin
write(out_line,to_bitvector(DDS_Out));
writeline(out_file,out_line);
end process;
END;
