(1)Full Chip Simulation: Freescale Full Chip Simulation with simulation of on-chip peripherals. Later on in the debugger you can switch to hardware debugging. (2)P&E Multilink/Cyclone Pro: Connect to P&E BDM Multilink (USB and parallel) or P&E Cyclone Pro (USB, Serial and TCP/IP). (3)SofTec HCS12: Connect to any of the USB-based SofTec Microsystems tools for HCS12 (inDART-HCS12, etc...). (4)Abatron BDI: Connect to the hardware board using Abatron hardware (BDI-HS or BDI1000) through BDM connection. (5)HCS12 Serial Monitor: Connect to a board through Freescale HCS12 Serial Monitor. Freescale HCS12 Serial Monitor must be on the board before connecting. (6)TBDML: Connect to a board through Freescale TBDML (TurboBDM Light). 这些目标工程分别怎么理解?谁有这方面的资料文档,能否传一份给我,我的邮箱是g_xiaocheng@sina.com,谢谢! |
