[求助]nios下载问题?再问,谢谢!
[求助]nios下载问题?再问,谢谢!
感谢caopengly之前的答复,我是准备在SRAM上跑,可是不行,而且又有新情况
我晕阿,到底要我怎么样呢?
我用ByteBlasterMV在sram上run的时候,它提示我,要用一个USB的,如下:
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterMV [LPT1]", device 1, instance 0
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems.  You may experience intermittent JTAG communication
nios2-terminal: failures with this cable.  Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable.  Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
我换成了USB的,它又提示我,说没有cpu,如下,而且更可恶的是,每次运行完它就找不到JTAG了,但是用ByteBlasterMV就不会出现这样的问题,这到底是为什么啊,请指教!
There are no Nios II CPUs with debug modules available which match the values
specified.  Please check that your PLD is correctly configured, downloading a
new SOF file if necessary.
[此贴子已经被作者于2007-1-13 17:43:26编辑过]
