PIC18F4515解密研究资料
PIC18F4515解密研究资料
世纪芯专业提供各种IC芯片和单片机的解密服务,涵盖典型的FPGA解密、MASK掩膜芯片解密、MSP430解密、PIC解密、AT88解密、ISPLSI芯片解密、gal芯片解密、WSI/PSD解密、TOSHIBA解密、MC9S08解密、ARM芯片解密、CPLD解密等。
长期提供高效、高可靠性、低成本、短周期的解密服务。有PIC18F4515解密需求者欢迎与我们联系详细的解密合作详情。
电  话:0755-83035861
咨询QQ:992091822
Features
·Up to 10 MIPS performance
·Ccompiler optimized RISC architecture
·8 x 8 Single Cycle Hardware Multiply System
·Internal oscillator support - 31 kHz to 8 MHz, up to 32 MHz with 4X PLL
·Fail-Safe Clock Monitor – allows safe shutdown if clock fails
·Watchdog Timer with separate RC oscillator
·Wide operating Voltage range; 2.0V to 5.5V nanoWatt Power Managed Modes
·Run, Idle and Sleep modes
·Idle mode currents down to 5.8uA typical
·Sleep mode currents down to 0.1uA typical
Analog Features
·10-bit ADC, 13 channels, 100K samples per second
·Programmable Low Voltage Detection Module
·Programmable Brown-out Reset module
·Two Analog comparators with input multiplexing
Peripherals
·Master Synchronous Serial Port supports SPI and I2C Master and Slave Mode
·EUSART module including LIN bus support
·Four Timer Modules
·Up to 5 PWM outputs
·Up to 2 Capture / Compare
