3. 动态代理类的源码分析 通过运行Main,我们会得到一个名为“$Proxy”的class文件,这个文件即为动态生成的代理类,我们通过反编译来查看下这个代理类的源代码:
package com.sun.proxy;import java.lang.reflect.InvocationHandler;import java.lang.reflect.Method;import java.lang.reflect.Proxy;import java.lang.reflect.UndeclaredThrowableException;public final class $Proxy0 extends Proxy implements Sell { //这5个Method对象分别代表equals()、toString()、ad()、sell()、hashCode()方法 private static Method m1; private static Method m2; private static Method m4; private static Method m3; private static Method m0; //构造方法接收一个InvocationHandler对象为参数,这个对象就是代理类的“直接委托类”(真正的委托类可以看做代理类的“间接委托类”) public $Proxy0(InvocationHandler var1) throws { super(var1); } //对equals方法的调用实际上转为对super.h.invoke方法的调用,父类中的h即为我们在构造方法中传入的InvocationHandler对象,以下的toString()、sell()、ad()、hashCode()等方法同理 public final boolean equals(Object var1) throws { try { return ((Boolean)super.h.invoke(this, m1, new Object[]{var1})).booleanValue(); } catch (RuntimeException | Error var3) { throw var3; } catch (Throwable var4) { throw new UndeclaredThrowableException(var4); } } public final String toString() throws { try { return (String)super.h.invoke(this, m2, (Object[])null); } catch (RuntimeException | Error var2) { throw var2; } catch (Throwable var3) { throw new UndeclaredThrowableException(var3); } } public final void ad() throws { try { super.h.invoke(this, m4, (Object[])null); } catch (RuntimeException | Error var2) { throw var2; } catch (Throwable var3) { throw new UndeclaredThrowableException(var3); } } public final void sell() throws { try { super.h.invoke(this, m3, (Object[])null); } catch (RuntimeException | Error var2) { throw var2; } catch (Throwable var3) { throw new UndeclaredThrowableException(var3); } } public final int hashCode() throws { try { return ((Integer)super.h.invoke(this, m0, (Object[])null)).intValue(); } catch (RuntimeException | Error var2) { throw var2; } catch (Throwable var3) { throw new UndeclaredThrowableException(var3); } } //这里完成Method对象的初始化(通过反射在运行时获得Method对象) static { try { m1 = Class.forName("java.lang.Object").getMethod("equals", new Class[]{Class.forName("java.lang.Object")}); m2 = Class.forName("java.lang.Object").getMethod("toString", new Class[0]); m4 = Class.forName("Sell").getMethod("ad", new Class[0]); m3 = Class.forName("Sell").getMethod("sell", new Class[0]); m0 = Class.forName("java.lang.Object").getMethod("hashCode", new Class[0]); } catch (NoSuchMethodException var2) { throw new NoSuchMethodError(var2.getMessage()); } catch (ClassNotFoundException var3) { throw new NoClassDefFoundError(var3.getMessage()); } }}
我们可以看到,以上代码的逻辑十分简单,我们在注释中也做出了相关的说明。(以上代码中涉及到反射的使用,对于反射还不是很熟悉的小伙伴可以参考这里: )
现在,我们已经了解了动态代理的使用,也搞清楚了它的实现原理,更进一步的话我们可以去了解动态代理类的生成过程,只需要去阅读newProxyInstance方法的源码即可,这个方法的逻辑也没有复杂的地方,这里就不展开了。 |
