S3C2410的WINCE BSP添加串口支持 03
else if(pHWHead1->dwIOBase == 0x50008000)
pHWHead->bINT = BIT_UART2;
pHWHead->bTxINT = INTSUB_TXD2;
pHWHead->bRxINT = INTSUB_RXD2;
pHWHead->bErrINT = INTSUB_ERR2;
#if USEVIRTUAL
pHWHead->s2410SerReg = (S2410_UART_REG *)v_pUART2regs;
pRegBase = (PUCHAR)pHWHead->s2410SerReg;
#else
pRegBase = (PUCHAR)UART2_BASE;
pHWHead->s2410SerReg = (S2410_UART_REG *)pRegBase;
#endif
else
{ pHWHead->bINT = BIT_UART0;
pHWHead->bTxINT = INTSUB_TXD0;
pHWHead->bRxINT = INTSUB_RXD0;
pHWHead->bErrINT = INTSUB_ERR0;
#if USEVIRTUAL
pHWHead->s2410SerReg = (S2410_UART_REG *)v_pUART0regs;
#else
pRegBase = (PUCHAR)UART0_BASE;
#endif
    再搜索:
if ( pHWHead->UseIrDA )
pHWHead->pUFTXH = (volatile unsigned char *)&(v_pUART2regs->rUTXH);
pHWHead->pUFRXH = (volatile unsigned char *)&(v_pUART2regs->rURXH);
else
把这其中的代码修改为以下代码
} if(pHWHead1->dwIOBase == 0x50004000)
pHWHead->pUFTXH = (volatile unsigned char *)&(v_pUART1regs->rUTXH);
pHWHead->pUFRXH = (volatile unsigned char *)&(v_pUART1regs->rURXH);
else
pHWHead->pUFTXH = (volatile unsigned char *)&(v_pUART0regs->rUTXH);
pHWHead->pUFRXH = (volatile unsigned char *)&(v_pUART0regs->rURXH);
    4、打开ser2410_ser.c文件。
      搜索:
const HWOBJ IoObj = {
THREAD_AT_INIT,
SYSINTR_SERIAL,
(PHW_VTBL) &IoVTbl
