谢谢版主!
我看他MC9S08GB60AD中对其AD说明那块
Maximum ATD conversion clock frequency is 2 MHz. The max bus clock frequency is computed from the max ATD
conversion clock frequency times the indicated prescaler setting; i.e., for a PRS of 0, max bus clock = 2 (max ATD
conversion clock frequency) × 2 (Factor) = 4 MHz.
怎么感觉像是反推回bus clock 的?
还有就是我接受到的波形,如果输入是5Hz大概一个周期50个点,10Hz一个周期25个点,20Hz一个周期18个点,他们三者之间满足相应的比例关系,但这样反推回去采样频率就只有大概250Hz左右阿,我实在是不明白这点? |
