Linux那些事儿之我是Hub(26)支持计划生育--看代码的理由
北大校长马寅初先生曾斩钉截铁地跟毛主席讲:”中国人口太多是因为农村晚上没有电.”
因此,为了支持计划生育这项基本国策,每一个男人都有义务认真看一下电源管理的代码.
另一方面,虽然现在已经不住在农村了,但我一直坚定不移的认为,这个世界,最慢的是我家的网速,最快的是我家电表的转速.
所以,为了了解如何让电表转速更慢,让我们一起来看看usb子系统里是如何支持电源管理的吧.
上节说了应该从usb_suspend/usb_resume开始看,那就开始吧.
usb_suspend/usb_resume这两个函数很显然是一对,但是我们不可能同时讲,只能一个一个来.倒不是故意把它们拆开,实在是没有办法.须知,形影不离并不代表相知相惜,感情在乎的是心与心的距离.两情若是久长时,又岂在朝朝暮暮. 先讲usb_suspend,再讲usb_resume.
来看usb_suspend,定义于drivers/usb/core/driver.c:
   1497 static int usb_suspend(struct device *dev, pm_message_t message)
   1498 {
   1499         if (!is_usb_device(dev))        /* Ignore PM for interfaces */
1500                 return 0;
   1501         return usb_external_suspend_device(to_usb_device(dev), message);
   1502 }
刚说过,usb_suspendusb子系统提供给PM core调用的,所以这里两个参数dev/message都是那边传递过来的,要不是usb device当然就不用做什么了.直接返回.然后调用usb_external_suspend_device(),后者也是来自drivers/usb/core/driver.c.
   1443 /**
   1444  * usb_external_suspend_device - external suspend of a USB device and its interfaces
   1445  * @udev: the usb_device to suspend
   1446  * @msg: Power Management message describing this state transition
   1447  *
   1448  * This routine handles external suspend requests: ones not generated
   1449  * internally by a USB driver (autosuspend) but rather coming from the user
   1450  * (via sysfs) or the PM core (system sleep).  The suspend will be carried
   1451  * out regardless of @udev's usage counter or those of its interfaces,
   1452  * and regardless of whether or not remote wakeup is enabled.  Of course,
   1453  * interface drivers still have the option of failing the suspend (if
   1454  * there are unsuspended children, for example).
   1455  *
   1456  * The caller must hold @udev's device lock.
   1457  */
   1458 int usb_external_suspend_device(struct usb_device *udev, pm_message_t msg)
   1459 {
   1460         int     status;
   1461
   1462         usb_pm_lock(udev);
   1463         udev->auto_pm = 0;
   1464         status = usb_suspend_both(udev, msg);
   1465         usb_pm_unlock(udev);
   1466         return status;
   1467 }
1462行和1465,锁的代码暂时先一律飘过.
我们看到,这个函数就做了两件事情,第一,udevauto_pm0,第二,调用usb_suspend_both.
继续跟踪usb_suspend_both.仍然是来自于drivers/usb/core/driver.c:
    993 /**
    994  * usb_suspend_both - suspend a USB device and its interfaces
    995  * @udev: the usb_device to suspend
    996  * @msg: Power Management message describing this state transition
    997  *
    998  * This is the central routine for suspending USB devices.  It calls the
    999  * suspend methods for all the interface drivers in @udev and then calls
   1000  * the suspend method for @udev itself.  If an error occurs at any stage,
   1001  * all the interfaces which were suspended are resumed so that they remain
   1002  * in the same state as the device.
   1003  *
   1004  * If an autosuspend is in progress (@udev->auto_pm is set), the routine
   1005  * checks first to make sure that neither the device itself or any of its
   1006  * active interfaces is in use (pm_usage_cnt is greater than 0).  If they
   1007  * are, the autosuspend fails.
   1008  *
   1009  * If the suspend succeeds, the routine recursively queues an autosuspend
   1010  * request for @udev's parent device, thereby propagating the change up
   1011  * the device tree.  If all of the parent's children are now suspended,
   1012  * the parent will autosuspend in turn.
   1013  *
   1014  * The suspend method calls are subject to mutual exclusion under control
   1015  * of @udev's pm_mutex.  Many of these calls are also under the protection
   1016  * of @udev's device lock (including all requests originating outside the
   1017  * USB subsystem), but autosuspend requests generated by a child device or
   1018  * interface driver may not be.  Usbcore will insure that the method calls
   1019  * do not arrive during bind, unbind, or reset operations.  However, drivers
   1020  * must be prepared to handle suspend calls arriving at unpredictable times.
   1021  * The only way to block such calls is to do an autoresume (preventing
   1022  * autosuspends) while holding @udev's device lock (preventing outside
   1023  * suspends).
   1024  *
   1025  * The caller must hold @udev->pm_mutex.
   1026  *
   1027  * This routine can run only in process context.
   1028  */
   1029 static int usb_suspend_both(struct usb_device *udev, pm_message_t msg)
   1030 {
   1031         int                     status = 0;
   1032         int                     i = 0;
   1033         struct usb_interface    *intf;
   1034         struct usb_device       *parent = udev->parent;
   1035
   1036         if (udev->state == USB_STATE_NOTATTACHED ||
   1037                         udev->state == USB_STATE_SUSPENDED)
   1038                 goto done;
   1039
   1040         udev->do_remote_wakeup = device_may_wakeup(&udev->dev);
   1041
   1042         if (udev->auto_pm) {
   1043                 status = autosuspend_check(udev);
   1044                 if (status < 0)
   1045                         goto done;
   1046         }
   1047
   1048         /* Suspend all the interfaces and then udev itself */
   1049         if (udev->actconfig) {
   1050                 for (; i < udev->actconfig->desc.bNumInterfaces; i++) {
   1051                         intf = udev->actconfig->interface;
   1052                         status = usb_suspend_interface(intf, msg);
   1053                         if (status != 0)
   1054                                 break;
   1055                 }
   1056         }
   1057         if (status == 0)
   1058                 status = usb_suspend_device(udev, msg);
   1059
   1060         /* If the suspend failed, resume interfaces that did get suspended */
   1061         if (status != 0) {
   1062                 while (--i >= 0) {
   1063                         intf = udev->actconfig->interface;
   1064                         usb_resume_interface(intf);
   1065                 }
   1066
   1067                 /* Try another autosuspend when the interfaces aren't busy */
   1068                 if (udev->auto_pm)
   1069                         autosuspend_check(udev);
   1070
   1071         /* If the suspend succeeded, propagate it up the tree */
   1072         } else {
   1073                 cancel_delayed_work(&udev->autosuspend);
   1074                 if (parent)
   1075                         usb_autosuspend_device(parent);
   1076         }
   1077
   1078  done:
   1079         // dev_dbg(&udev->dev, "%s: status %d/n", __FUNCTION__, status);
   1080         return status;
   1081 }
这里有两个重要的概念,autosuspend/autoresume.autosuspend,即自动挂起,这是由driver自行决定,它自己进行判断,当它觉得应该挂起设备的时候,它就会去Just do it!关于autosuspend我们后面会讲.
1040, device_may_wakeup(),我们前面说过,设备有没有被唤醒的能力有一个flag可以标志,can_wakeup,那么如果有这种能力,用户仍然可以根据实际需要关掉这种能力,或者打开这种能力,这就体现在sysfs下的一个文件.比如:
localhost:~ # cat /sys/bus/usb/devices/1-5/power/wakeup
enabled
localhost:~ # cat /sys/bus/usb/devices/1-5/:1.0/power/wakeup
localhost:~ #
可以看到后者的输出值为空,这说明该设备是不支持remote wakeup,换句话说,can_wakeup也应该是设置为了0,这种情况device_may_wakeup返回值必然是false,而前者的输出值为enabled,说明该设备是支持remote wakeup,并且此刻remote wakeup的特性是打开的.别的设备也一样,用户可以通过sysfs来进行设置,你可以把wakeupenabled改为disabled.
为什么需要有这么一个sysfs的接口呢?我们知道usb设备有一种特性,叫做remote wakeup,这种特性不是每个usb设备都支持,而一个设备是否支持remote wakeup可以在它的配置描述符里体现出来,但问题是,以前,区里的人们总是相信设备的各种描述符,可是你知道,现实生活中,被骗比骗人容易.制造商生产出来的产品总是有着各种问题的,它的各种描述符也许只是一种假象,比如,很多案例表明,一个设备的配置描述里声称自己支持remote wakeup,但是实际上却并不支持,当它进入睡眠之后,你根本唤不醒它.所以弟兄们学乖了,决定为用户提供一种选择,,用户可以自己打开或者关闭这种特性,就为了对付这种设备掩耳盗铃自欺欺人的社会现象.不过仔细想想,其实制造商也不容易,也许他们想通过这些设备传达一种思想,那就是:人们总说快乐很难,其实快乐很容易,只要你学会欺骗自己,你天天都是快乐的.
那么我们这里用udev->do_remote_wakeup来记录下这个值,日后会用得着的,到时候再看.
1042,刚才咱们设置了auto_pm0,所以这段不会执行.如果我们设置了auto_pm1,那么就会调用.autosuspend_check(),这个函数我们以后再回过来看.现在先根据我们实际的情景走,不执行.auto_pm0就是告诉人们我们现在没有做autosuspend.以后我们会看到,auto_pm这个变量将在autosuspend的代码中被设置为1.
接下来是一段循环,按接口进行循环,,设备有几个接口,就循环几次,因为我们知道usb,驱动程序往往是针对interface,而不是针对device,所以每一个interface就可能对应一个驱动程序,进而就可能有一个单独的suspend函数.
遍历各个接口之后,usb_suspend_interface这个函数如果能够顺利的把各个接口都给挂起了,那么再调用一个usb_suspend_device函数来执行一次总的挂起.为什么要有这两个函数我们看了就知道.先看第一个,usb_suspend_interface,来自drivers/usb/core/driver.c:
850 /* Caller has locked intf's usb_device's pm mutex */
    851 static int usb_suspend_interface(struct usb_interface *intf, pm_message_t msg)
    852 {
    853         struct usb_driver       *driver;
    854         int                     status = 0;
    855
    856         /* with no hardware, USB interfaces only use FREEZE and ON states */
    857         if (interface_to_usbdev(intf)->state == USB_STATE_NOTATTACHED ||
    858                         !is_active(intf))
    859                 goto done;
    860
    861         if (intf->condition == USB_INTERFACE_UNBOUND)   /* This can't happen */
    862                 goto done;
    863         driver = to_usb_driver(intf->dev.driver);
    864
    865         if (driver->suspend && driver->resume) {
    866                 status = driver->suspend(intf, msg);
    867                 if (status == 0)
    868                         mark_quiesced(intf);
    869                 else if (!interface_to_usbdev(intf)->auto_pm)
870                         dev_err(&intf->dev, "%s error %d/n",
871                                         "suspend", status);
    872         } else {
    873                 // FIXME else if there's no suspend method, disconnect...
    874                 // Not possible if auto_pm is set...
    875                 dev_warn(&intf->dev, "no suspend for driver %s?/n",
    876                                 driver->name);
    877                 mark_quiesced(intf);
    878         }
    879
    880 done:
    881         // dev_dbg(&intf->dev, "%s: status %d/n", __FUNCTION__, status);
    882         if (status == 0)
    883                 intf->dev.power.power_state.event = msg.event;
    884         return status;
    885 }
一路陪我们走过来的兄弟们一定不会看不懂这个函数,最关键的代码就是866那行,driver->suspend(intf,msg),这就是调用具体的interface所绑定的那个驱动程序的suspend函数.比如,对于hub来说,这里调用的就是hub_suspend()函数.具体的hub_suspend()我们倒是不用先急着看,顺着现在的情景往下过一遍,至于hub_suspend/hub_resume,咱们跟它秋后算账.
mark_quiesced是一个内联函数,咱们一次性把相关的三个内联函数都贴出来,来自drivers/usb/core/usb.h:
     98 /* Interfaces and their "power state" are owned by usbcore */
     99
    100 static inline void mark_active(struct usb_interface *f)
    101 {
    102         f->is_active = 1;
    103 }
    104
    105 static inline void mark_quiesced(struct usb_interface *f)
    106 {
    107         f->is_active = 0;
    108 }
    109
    110 static inline int is_active(const struct usb_interface *f)
    111 {
    112         return f->is_active;
    113 }
其实就是struct usb_interface中有一个成员,unsigned is_active,这位为1就标志该interface没有suspended.反之就是记录该interface已经是suspended.suspended了也被老外称作quiesced,反之就叫做active.所以呢,这里对应的两个函数就叫做mark_activemark_quiesced.
