- 来自
- 北京
用软件实现的异步串行口源程序代码
//串口中断服务程序,仅需做简单调用即可完成串口输入输出的处理
//出入均设有缓冲区,大小可任意设置。
#i nclude "TestSerial.h"
#define BAUDRATE0 115200 // 用户定义的UART0 波特率
#define DB_SENDMAXSIZE 0xf0
#define DB_RECMAXSIZE 0xf0
bit CommRecDataOverflowFlag,FlagRecComm,SendItComm;
extern unsigned char Count1ms;
unsigned char CommSendBufferHead, CommSendBufferTail;
unsigned char xdata CommSendBuffer[DB_SENDMAXSIZE];
unsigned char CommRecBufferHead, CommRecBufferTail;
unsigned char xdata CommRecBuffer[DB_RECMAXSIZE];
unsigned char RecDataLen=3;
void ClearCommRecBuffer(void)
CommRecBufferHead=CommRecBufferTail=0;
FlagRecComm=0;
void OpenComm(void)
PCON |= 0x80; // SMOD=1 (HW_UART uses Timer 1 overflow with no divide down).
TMOD = 0x20; // Configure Timer 1 for use by UART0
CKCON |= 0x10; // Timer 1 derived from SYSCLK
RCAP2H=(65536-(SYSCLK/BAUDRATE0/32))/256;
RCAP2L=(65536-(SYSCLK/BAUDRATE0/32))%256;
TH2=RCAP2H;TL2=RCAP2L;
CT2=0; //T2:timer mode
TR2=1;
TCLK=1;RCLK=1; //说明:52,对于SIO0,可选择T1(TCLK=0,RCLK=0)或T2(TCLK=1,RCLK=1)作为波特率发生器
// SIO1只能用T1作为波特率发生器
//baud=OSC/(32*(65536-[RCAP2H,RCAP2L])
CommSendBufferHead=CommSendBufferTail=0; // set the head and tail to the base of the ring buffer
FlagRecComm=0;
RI0=0; // Clear HW_UART receive and transmit
TI0=0; // complete indicators.
SCON0 = 0x50; // Configure UART0 for mode 1, receiver enabled.
ES0=1; // allow the serial interrupt
SendItComm=1;
void SendCommChar(char ch)
CommSendBuffer[CommSendBufferTail]=ch;
CommSendBufferTail++;
if (CommSendBufferTail==DB_SENDMAXSIZE)
if (SendItComm)
TB80=1;SBUF0=CommSendBuffer[CommSendBufferHead];
return ;
void SendCommString(unsigned char *base)
unsigned char i=0;
if (base[0]==0) return;
for (;;)
if (base==0) break;
CommSendBuffer[CommSendBufferTail]=base;
i++;
if (SendItComm)
void SendCommBuffer(unsigned char *base, unsigned char size)
unsigned char i=0;
if (!size) { return; }
while (i<size)
i++;
if (SendItComm)
void CommISR(void) interrupt 4
if (_testbit_(TI0))
TI0=0;
CommSendBufferHead++;
if (CommSendBufferHead==DB_SENDMAXSIZE)
CommSendBufferHead=0;
if (CommSendBufferHead!=CommSendBufferTail)
SBUF0=CommSendBuffer[CommSendBufferHead]; // send the next byte
SendItComm=0;
else
SendItComm=1;
if (_testbit_(RI0))
RI0=0;
if (CommRecBufferTail==CommRecBufferHead)
CommRecDataOverflowFlag=1; //接收缓冲区溢出
CommRecBuffer[CommRecBufferTail]=SBUF0; //receive data
CommRecBufferTail++;
if (CommRecBufferTail==DB_RECMAXSIZE)
FlagRecComm=1;
//从接收缓冲区读数据 ,无数据返回0,有数据返回1
bit GetCommChar(unsigned char idata *ch)
if (CommRecBufferTail==CommRecBufferHead) return 0;
*ch=CommRecBuffer[CommRecBufferHead];
CommRecBufferHead++;
if (CommRecBufferHead==DB_RECMAXSIZE)
CommRecBufferHead=0;
if (CommRecBufferTail==CommRecBufferHead) FlagRecComm=0;
return 1;
//在T(0-255)毫秒内从接收缓冲区读数据 ,无数据返回0,有数据返回1
bit GetCommCharWait(unsigned char idata *ch,unsigned char T) //T ms
Count1ms=T;*ch=0;
while (Count1ms)
if (CommRecBufferTail!=CommRecBufferHead) break;
if (Count1ms==0) return 0;
return 1;
