Unix/Linux 系统自动化管理 系统更新篇(4)
(5)获取需要在节点上进行安装的 rpm 包代码清单
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
sub getNodeRpmList
    my ($rpmlistfile) = @_;
    my @shortnamelist;
    open(RPMLIST,"<$rpmlistfile")
        || print "Fail to open rpm list file.\n";
    while (<RPMLIST>) {
            chomp;
            if ( $_ =~ /^#.*$/ ) {
                    next;
            #$rpmliststring = $rpmliststring ." " . $_;
            push @shortnamelist , $_;
   close(RPMLIST);
    my %temphash;
    #Remove repeated entry from namelist
    foreach my $rpmname (@shortnamelist)
        $temphash{$rpmname} = 1 if (defined $rpmname);
   @shortnamelist = keys %temphash;
    $rpmliststring = join(" ",@shortnamelist);
   print "rpmliststring = $rpmliststring \n" if $:EBUG;
    return $rpmliststring;
(6)main 入口主体部分 .
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
105
#!/usr/bin/perl
use strict;
#main()
my $updateSWConf;
my @children = ();
my $pid;
my $retVal = 0;
# 命令行参数解析
if ($ARGV[0] eq "-c")
    $updateSWConf = $ARGV[1];
    if( $updateSWConf eq "" )
        $updateSWConf = "/etc/updateSW.conf";
# 检查是否指定需要更新的节点
if ( ($ARGV[2] ne "-n") || ($ARGV[2] eq "") || ($ARGV[3] eq "") )
    print "pls specify the updated nodes with – n.\n";
my $argLine = $ARGV[3];
chomp($argLine);
my @nodeNameArray = split ",", $argLine;
# 创建 yum 配置文件
createyumConf($::distro_name, $::repo_base_url, $::repo_base_name);
# 创建 yum 软件仓库
$retVal = createRepo($::NODE_YUM_CONF_FILE)
if ($retVal == 1) exit 1;
# 获取每个节点需要更新的软件包的列表
my $rpmList = getNodeRpmList($updateSWConf);
# 对每个节点进行轮循
foreach my $nodeName (@nodeNameArray)
    if ($nodeName eq "")
        continue;
    FORK:
       # 针对每个节点创建进程
       if ($pid = fork)
            #parent, store pid in array
           push(@children, $pid);
       elsif (defined $pid)
           # 将创建的 yum 配置文件传送到需要被远程部署的节点上
           #child, issue the update command
            $retVal = runCmd("scp $::NODE_YUM_CONF_FILE \
                root@nodeName::NODE_YUM_CONF_DIR");
           if ($retVal)
                $retVal = 1;
                exit $retVal;
           # 将需要运行的更新脚本文件传送到需要被远程部署的节点上
            $retVal = runCmd("scp $::NODEUPDATESWCMD \
                root@nodeName::NODE_UPDATESWCMD_DIR");
           if ($retVal)
                $retVal = 1;
                exit $retVal;
           # 通过 shh 在远程节点上执行更新脚本,进行软件更新
           $retVal = runCmd("ssh root@nodeName '$::NODEUPDATESWCMD – s 1 – c \
               $::NODE_YUM_CONF_FILE – n $rpmList'");
           if ($retVal)
                $retVal = 1;
           exit $retVal;
       else
           #couldn't fork, can't use msg catalog since no
           # procs are available.
           printf "updateLinuxSW: Unable to fork child process.\n";
#wait until all children processes have ended.
foreach $pid (@children)
    waitpid($pid, 0);
undef @children;
exit 0;
updateSWorSys.pl 文件                         命令格式:updateSWorSys.pl – s IsUpdateSWFlag – c nodeyumConfile – p rpmList
该可执行文件主要包含在各节点上执行的 yum 进行升级与更新软件包或系统代码。
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
#!/usr/bin/perl
use strict;
#main()
my $IsUpdateSW;
my $nodeyumConfile;
my $output;
# 命令行参数解析
if ($ARGV[0] eq "-s")
    $IsUpdatSW = $ARGV[1];
    if( $IsUpdatSW eq "" )
        $IsUpdatSW = 1;
else
    $IsUpdatSW = 1;
# 检查是否指定了 yum 配置文件
if ($ARGV[2] eq "-c")
    $nodeyumConfile = $ARGV[3];
    if( $nodeyumConfile eq "" )
        $nodeyumConfile = "/var/opt/yum/config/yum.conf";
# 检查是否指定了需要更新的软件名
if ( ($ARGV[4] ne "-p") || ($ARGV[4] eq "") || ($ARGV[4] eq "") )
    print "pls specify the updated software name with – p.\n";
my $nodeSWName = $ARGV[5];
# 判断是进行软件更新还是系统更新
if ($IsUpdateSW)
    $output = runCmd("yum -y -c $nodeyumConfile update $nodeSWName", -1);
else
    $output = runCmd("yum -y -t -d 2 -c $nodeyumConfile update", -1);
if ( defined($:EBUG) )
    print "The yum output: $output\n";
if ($::RETVAL)
    print "yum errors, please refer to the yum output for details";
    $$::RETVAL = 1;
exit $::RETVAL;
