Linux下PCI设备驱动程序开发 03
包括厂商ID、设备ID、各种资源等:
struct pci_dev {
struct list_head global_list;
struct list_head bus_list;
struct pci_bus *bus;
struct pci_bus *subordinate;
void *sysdata;
struct proc_dir_entry *procent;
unsigned int devfn;
unsigned short vendor;
unsigned short device;
unsigned short subsystem_vendor;
unsigned short subsystem_device;
unsigned int class;
u8 hdr_type;
u8 rom_base_reg;
struct pci_driver *driver;
void *driver_data;
u64 dma_mask;
u32 current_state;
unsigned short vendor_compatible[DEVICE_COUNT_COMPATIBLE];
unsigned short device_compatible[DEVICE_COUNT_COMPATIBLE];
unsigned int irq;
struct resource resource[DEVICE_COUNT_RESOURCE];
struct resource dma_resource[DEVICE_COUNT_DMA];
struct resource irq_resource[DEVICE_COUNT_IRQ];
char name[80];
char slot_name[8];
int active;
int ro;
unsigned short regs;
int (*prepare)(struct pci_dev *dev);
int (*activate)(struct pci_dev *dev);
int (*deactivate)(struct pci_dev *dev);
2. 基本框架
在用模块方式实现PCI设备驱动程序时,通常至少要实现以下几个部分:初始化设备模块、设备打开模块、数据读写和控制模块、中断处理模块、设备释放模块、设备卸载模块。下面给出一个典型的PCI设备驱动程序的基本框架,从中不难体会到这几个关键模块是如何组织起来的。
/* 指明该驱动程序适用于哪一些PCI设备 */
static struct pci_device_id demo_pci_tbl [] __initdata = {
{PCI_VENDOR_ID_DEMO, PCI_DEVICE_ID_DEMO,
PCI_ANY_ID, PCI_ANY_ID, 0, 0, DEMO},
{0,}
/* 对特定PCI设备进行描述的数据结构 */
struct demo_card {
unsigned int magic;
/* 使用链表保存所有同类的PCI设备 */
struct demo_card *next;
/* 中断处理模块 */
static void demo_interrupt(int irq, void *dev_id, struct pt_regs *regs)
/* 设备文件操作接口 */
static struct file_operations demo_fops = {
owner: THIS_MODULE, /* demo_fops所属的设备模块 */
read: demo_read, /* 读设备操作*/
write: demo_write, /* 写设备操作*/
ioctl: demo_ioctl, /* 控制设备操作*/
mmap: demo_mmap, /* 内存重映射操作*/
open: demo_open, /* 打开设备操作*/
release: demo_release /* 释放设备操作*/
/* 设备模块信息 */
static struct pci_driver demo_pci_driver = {
name: demo_MODULE_NAME, /* 设备模块名称 */
id_table: demo_pci_tbl, /* 能够驱动的设备列表 */
probe: demo_probe, /* 查找并初始化设备 */
remove: demo_remove /* 卸载设备模块 */
static int __init demo_init_module (void)
static void __exit demo_cleanup_module (void)
pci_unregister_driver(&demo_pci_driver);
/* 加载驱动程序模块入口 */
module_init(demo_init_module);
/* 卸载驱动程序模块入口 */
module_exit(demo_cleanup_module);
上面这段代码给出了一个典型的PCI设备驱动程序的框架,是一种相对固定的模式。需要注意的是,同加载和卸载模块相关的函数或数据结构都要在前面加上__init、__exit等标志符,以使同普通函数区分开来。构造出这样一个框架之后,接下去的工作就是如何完成框架内的各个功能模块了。
3. 初始化设备模块
在Linux系统下,想要完成对一个PCI设备的初始化,需要完成以下工作:
检查PCI总线是否被Linux内核支持;
检查设备是否插在总线插槽上,如果在的话则保存它所占用的插槽的位置等信息。
读出配置头中的信息提供给驱动程序使用。
当Linux内核启动并完成对所有PCI设备进行扫描、登录和分配资源等初始化操作的同时,会建立起系统中所有PCI设备的拓扑结构,此后当PCI驱动程序需要对设备进行初始化时,一般都会调用如下的代码:
/* 检查系统是否支持PCI总线 */
if (!pci_present())
return -ENODEV;
/* 注册硬件驱动程序 */
if (!pci_register_driver(&demo_pci_driver)) {
return -ENODEV;
return 0;
驱动程序首先调用函数pci_present( )检查PCI总线是否已经被Linux内核支持,如果系统支持PCI总线结构,这个函数的返回值为0,如果驱动程序在调用这个函数时得到了一个非0的返回值,那么驱动程序就必须得中止自己的任务了。在2.4以前的内核中,需要手工调用pci_find_device( )函数来查找PCI设备,但在2.4以后更好的办法是调用pci_register_driver( )函数来注册PCI设备的驱动程序,此时需要提供一个pci_driver结构,在该结构中给出的probe探测例程将负责完成对硬件的检测工作。
static int __init demo_probe(struct pci_dev *pci_dev, const struct pci_device_id *pci_id)
struct demo_card *card;
/* 启动PCI设备 */
if (pci_enable_device(pci_dev))
return -EIO;
/* 设备DMA标识 */
if (pci_set_dma_mask(pci_dev, DEMO_DMA_MASK)) {
return -ENODEV;
/* 在内核空间中动态申请内存 */
if ((card = kmalloc(sizeof(struct demo_card), GFP_KERNEL)) == NULL) {
printk(KERN_ERR "pci_demo: out of memory\n");
return -ENOMEM;
memset(card, 0, sizeof(*card));
/* 读取PCI配置信息 */
card->iobase = pci_resource_start (pci_dev, 1);
card->pci_dev = pci_dev;
card->pci_id = pci_id->device;
card->irq = pci_dev->irq;
card->next = devs;
card->magic = DEMO_CARD_MAGIC;
/* 设置成总线主DMA模式 */
pci_set_master(pci_dev);
/* 申请I/O资源 */
request_region(card->iobase, 64, card_names[pci_id->driver_data]);
return 0;
4. 打开设备模块
在这个模块里主要实现申请中断、检查读写模式以及申请对设备的控制权等。在申请控制权的时候,非阻塞方式遇忙返回,否则进程主动接受调度,进入睡眠状态,等待其它进程释放对设备的控制权。
static int demo_open(struct inode *inode, struct file *file)
/* 申请中断,注册中断处理程序 */
request_irq(card->irq, &demo_interrupt, SA_SHIRQ,
card_names[pci_id->driver_data], card)) {
/* 检查读写模式 */
if(file->f_mode & FMODE_READ) {
if(file->f_mode & FMODE_WRITE) {
/* 申请对设备的控制权 */
down(&card->open_sem);
while(card->open_mode & file->f_mode) {
if (file->f_flags & O_NONBLOCK) {
/* NONBLOCK模式,返回-EBUSY */
up(&card->open_sem);
return -EBUSY;
} else {
/* 等待调度,获得控制权 */
card->open_mode |= f_mode & (FMODE_READ | FMODE_WRITE);
/* 设备打开计数增1 */
MOD_INC_USE_COUNT;
5. 数据读写和控制信息模块
PCI设备驱动程序可以通过demo_fops 结构中的函数demo_ioctl( ),向应用程序提供对硬件进行控制的接口。例如,通过它可以从I/O寄存器里读取一个数据,并传送到用户空间里:
static int demo_ioctl(struct inode *inode, struct file *file, unsigned int cmd, unsigned long arg)
switch(cmd) {
case DEMO_RDATA:
/* 从I/O端口读取4字节的数据 */
val = inl(card->iobae + 0x10);
/* 将读取的数据传输到用户空间 */
return 0;
事实上,在demo_fops里还可以实现诸如demo_read( )、demo_mmap( )等操作,Linux内核源码中的driver目录里提供了许多设备驱动程序的源代码,找那里可以找到类似的例子。在对资源的访问方式上,除了有I/O指令以外,还有对外设I/O内存的访问。对这些内存的操作一方面可以通过把I/O内存重新映射后作为普通内存进行操作,另一方面也可以通过总线主DMA(Bus Master DMA)的方式让设备把数据通过DMA传送到系统内存中。
6. 中断处理模块
PC的中断资源比较有限,只有0~15的中断号,因此大部分外部设备都是以共享的形式申请中断号的。当中断发生的时候,中断处理程序首先负责对中断进行识别,然后再做进一步的处理。
struct demo_card *card = (struct demo_card *)dev_id;
u32 status;
spin_lock(&card->lock);
/* 识别中断 */
status = inl(card->iobase + GLOB_STA);
if(!(status & INT_MASK))
spin_unlock(&card->lock);
return; /* not for us */
/* 告诉设备已经收到中断 */
outl(status & INT_MASK, card->iobase + GLOB_STA);
/* 其它进一步的处理,如更新DMA缓冲区指针等 */
7. 释放设备模块
释放设备模块主要负责释放对设备的控制权,释放占用的内存和中断等,所做的事情正好与打开设备模块相反:
static int demo_release(struct inode *inode, struct file *file)
/* 释放对设备的控制权 */
card->open_mode &= (FMODE_READ | FMODE_WRITE);
/* 唤醒其它等待获取控制权的进程 */
wake_up(&card->open_wait);
/* 释放中断 */
free_irq(card->irq, card);
/* 设备打开计数增1 */
MOD_DEC_USE_COUNT;
8. 卸载设备模块
卸载设备模块与初始化设备模块是相对应的,实现起来相对比较简单,
