Cell 编程登堂入室(2)简单编程实现
简单编程实现SDK3.0 中的 SPE 运行管理库完全摒弃了 libspe1.2 而采用了 libspe2。我们创建一个 test 目录来做一下 Cell 的简单编程,该 test 程序实现用 PPU 调度 SPU 计算 4 个整数乘 4 个浮点数的结果:
3
4
5
6
7
8
[root@wq_desktop ~]# mkdir -p test test/ppu test/spu
[root@wq_desktop ~]# cd test
[root@wq_desktop test]# vi Makefile
[root@wq_desktop test]# vi ppu/Makefile
[root@wq_desktop test]# vi spu/Makefile
[root@wq_desktop test]# vi ppu/test_p.c
[root@wq_desktop test]# vi spu/test_spu.c
[root@wq_desktop test]# make
3 个 Makefile 文件和两个 .c 文件的内容如下:
清单 1:3 个 Makefile 文件和两个 .c 文件
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
[root@wq_desktop test]# more Makefile
DIRS = spu ppu
include /opt/cell/sdk/buildutils/make.footer
[root@wq_desktop test]# more ppu/Makefile
PROGRAM_ppu :=  ../test
IMPORTS = ../spu/libtest_spu.a -lspe2 -lpthread
[root@wq_desktop test]# more spu/Makefile
PROGRAMS_spu    := test_spu
LIBRARY_embed   := libtest_spu.a
[root@wq_desktop test]# more ppu/test_p.c
#include <pthread.h>
#include <libspe2.h>
#define SPU_THREADS 2
extern spe_program_handle_t test_spu;
void *ppu_pthread_function(void *arg)
    spe_context_ptr_t ctx;
    unsigned int entry = SPE_DEFAULT_ENTRY;
    ctx = *((spe_context_ptr_t *)arg);
    if (spe_context_run(ctx, &entry, 0, NULL, NULL, NULL) < 0) {
        perror ("Failed running context");
        return NULL;
    pthread_exit(NULL);
int main ( )
    int i;
    spe_context_ptr_t ctxs[SPU_THREADS];
    pthread_t threads[SPU_THREADS];
    for(i=0; i<SPU_THREADS; i++)
        if ((ctxs = spe_context_create (0, NULL)) == NULL)
            perror ("Failed creating context");
            return -1;
        if (spe_program_load (ctxs, &test_spu))
            perror ("Failed loading program");
            return -1;
        if (pthread_create (&threads, NULL, &ppu_pthread_function, &ctxs))
            perror ("Failed creating thread");
            return -1;
    for (i=0; i<SPU_THREADS; i++)
        if (pthread_join (threads, NULL))
            perror("Failed pthread_join");
            return -1;
    return (0);
[root@wq_desktop test]# more spu/test_spu.c
#include <stdio.h>
int main()
    int a[4] = {120, 230, 580, 970};
    float b[4] = {1.8, 1.98, 0.68, 0.7};
    int c[4] = {0};
    int i = 0;
    for( i = 0; i < 4; i ++ )
        c = a * b;
        printf("c[%d] = %d\n", i, c);
    return 0;
在 test 目录下生成一个 test 可执行文件,需要将此文件 copy 到 mambo 环境里的 Linux 中才能运行,在 mambo 中的 console 窗口键入如下指令(图4):
图 4:在 mambo 的 Linux 中运行程序
