SPI的配置;
void spi_init()
        SpiaRegs.SPICCR.all =0x0007;                     // Reset on, rising edge, 16-bit char bits
        SpiaRegs.SPICTL.all =0x0006;                         // Enable master mode, normal phase,
           SpiaRegs.SPIBRR =0x00FF;                                             // enable talk, and SPI int disabled.
//        SpiaRegs.SPIBRR =0x0085;
    SpiaRegs.SPICCR.all =0x0087;                         // Relinquish SPI from Reset
    SpiaRegs.SPIPRI.bit.FREE = 1;                // Set so breakpoints don't disturb xmission
void spi_fifo_init()
// Initialize SPI FIFO registers
   SpiaRegs.SPIFFTX.all=0xE040;
   SpiaRegs.SPIFFRX.all=0x204F;
   SpiaRegs.SPIFFCT.all=0x0;
实际使用时:
                                AD_CS=0;
                                   SpiaRegs.SPITXBUF=DA_Data[0];
                                   SpiaRegs.SPITXBUF=DA_Data[1];
                                   SpiaRegs.SPITXBUF=DA_Data[2];
                                while(1)
                                        if((SpiaRegs.SPISTS.all&0x40)==1)        break;//如果的中断标志位为1,则证明SPI已经发送成功,则停止等待
                                SpiaRegs.SPIRXBUF=SpiaRegs.SPIRXBUF;//虚读SPIRXBUF,以清除SPI中断标志
                        //    while(SpiaRegs.SPIFFTX.bit.TXFFST!=0){}
                                AD_CS=1; |
