这个数据结构也在文件include/linux/pci.h里,它详细描述了一个PCI设备几乎所有的硬件信息,包括厂商ID、设备ID、各种资源等:
struct pci_dev {
struct list_head global_list;
struct list_head bus_list;
struct pci_bus *bus;
struct pci_bus *subordinate;
void *sysdata;
struct proc_dir_entry *procent;
unsigned int devfn;
unsigned short vendor;
unsigned short device;
unsigned short subsystem_vendor;
unsigned short subsystem_device;
unsigned int class;
u8 hdr_type;
u8 rom_base_reg;
struct pci_driver *driver;
void *driver_data;
u64 dma_mask;
u32 current_state;
unsigned short vendor_compatible[DEVICE_COUNT_COMPATIBLE];
unsigned short device_compatible[DEVICE_COUNT_COMPATIBLE];
unsigned int irq;
struct resource resource[DEVICE_COUNT_RESOURCE];
struct resource dma_resource[DEVICE_COUNT_DMA];
struct resource irq_resource[DEVICE_COUNT_IRQ];
char name[80];
char slot_name[8];
int active;
int ro;
unsigned short regs;
int (*prepare)(struct pci_dev *dev);
int (*activate)(struct pci_dev *dev);
int (*deactivate)(struct pci_dev *dev);
2. 基本框架
在用模块方式实现PCI设备驱动程序时,通常至少要实现以下几个部分:初始化设备模块、设备打开模块、数据读写和控制模块、中断处理模块、设备释放模块、设备卸载模块。下面给出一个典型的PCI设备驱动程序的基本框架,从中不难体会到这几个关键模块是如何组织起来的。
/* 指明该驱动程序适用于哪一些PCI设备 */
static struct pci_device_id demo_pci_tbl [] __initdata = {
{PCI_VENDOR_ID_DEMO, PCI_DEVICE_ID_DEMO,
PCI_ANY_ID, PCI_ANY_ID, 0, 0, DEMO},
{0,}
/* 对特定PCI设备进行描述的数据结构 */
struct demo_card {
unsigned int magic;
/* 使用链表保存所有同类的PCI设备 */
struct demo_card *next;
/* 中断处理模块 */
static void demo_interrupt(int irq, void *dev_id, struct pt_regs *regs)
/* 设备文件操作接口 */
static struct file_operations demo_fops = {
owner: THIS_MODULE, /* demo_fops所属的设备模块 */
read: demo_read, /* 读设备操作*/
write: demo_write, /* 写设备操作*/
ioctl: demo_ioctl, /* 控制设备操作*/
mmap: demo_mmap, /* 内存重映射操作*/
open: demo_open, /* 打开设备操作*/
release: demo_release /* 释放设备操作*/
/* 设备模块信息 */
static struct pci_driver demo_pci_driver = {
name: demo_MODULE_NAME, /* 设备模块名称 */
id_table: demo_pci_tbl, /* 能够驱动的设备列表 */
probe: demo_probe, /* 查找并初始化设备 */
remove: demo_remove /* 卸载设备模块 */
static int __init demo_init_module (void)
static void __exit demo_cleanup_module (void)
pci_unregister_driver(&demo_pci_driver);
/* 加载驱动程序模块入口 */
module_init(demo_init_module);
/* 卸载驱动程序模块入口 */
module_exit(demo_cleanup_module);
上面这段代码给出了一个典型的PCI设备驱动程序的框架,是一种相对固定的模式。需要注意的是, |
