[求助]How to initial PLIC to 78d11 codec
I use PLIC port 0 slave mode input dcl0=1024khz;port 1 master mode output dlc1=2048khz,fsc1=8khz puls to codec 78d11, but I can not output any wave to scope on Dout1,but I can see Din1 from 78d11 on scope.
I use the GCI mode.
Have any idea to initial the PLIC interface to output on Dout 1?
Thanks!
Chaucer |
What's the part number of the chip you are using? |
mcf5272 have a PLIC interface,I want use GCI to communication with SLAC(codec).but mcf5272 Dout1 can not see waveform on scope. |
The following application notes from freescale web site may be useful for you:
http://www.freescale.com/files/netcomm/doc/reports_presentations/5272PLIC.pdf (there is an example in p.19 - p.22)
http://www.freescale.com/files/netcomm/doc/app_note/AN2184.pdf |
