目前我遇到一个问题,在LCD显示时会出现的状况 先说下LCD是256?1的,分成了10页,每页Y方向有8个点。 当我显示的起始Y坐标位置不是8的倍数的时候,会调用下面这个函数去做显示。但是,问题是我发觉只要起始坐标位置不是8的倍数,在同一X坐标下(比如X1-X16,16个点那么宽),其他Y方向都会显示出连续的黑色区域,特点是每6个黑点2个白点。 ... ... ... ... ... ... 就像这样的一个模式。 而这个黑色区域,我先称之为连续的黑线。黑线从LCD显示的情况来看,是在我要显示的东西如“A”的后面,就是说是先显示了黑线,然后A再显示到黑线上面去的。 另外,我把显示内容比如一个A拆分成两个部分,分别在两个页面中显示,起始坐标选择是Y方向是能正常显示的。 我想麻烦各位达人帮我看下这段程序是否有问题。不胜感谢!!!!!! 这个函数是Y!=8的倍数的 unsigned char ucPLCD_eDisplayArea_Exe(unsigned int uiStartX, unsigned char ucStartY, \ unsigned int uiWidth, unsigned char ucHeight, \ unsigned char const * pucDataStart, unsigned char ucDrawMode) { unsigned char const * pucData; unsigned char * pucBuffer; unsigned char ucMaxHeight; /*maximum possible height with given ucStartY*/ unsigned char uiEndX; unsigned char ucXStartOff; unsigned char ucXPageMaxBits; unsigned char ucMask; unsigned char ucHeightTemp; unsigned char ucXPageRemBits; unsigned char ucTempData; if(ucStartY < DucDLCD_eHEIGHTSCREEN) { uiEndX = ((uiWidth+uiStartX) - 1); ucMaxHeight = (DucDLCD_eHEIGHTSCREEN-ucStartY); pucData = 0;
if(ucHeight > ucMaxHeight) { ucHeight = ucMaxHeight; } if(uiEndX >= DucDLCD_eWIDTHSCREEN) { uiEndX = (DucDLCD_eWIDTHSCREEN-1); } ucXStartOff = (ucStartY & 0x07); while(uiStartX <= uiEndX) { ucMask = ucDLCDMask[ucXStartOff]; ucXPageMaxBits = (8-ucXStartOff); ucHeightTemp = ucHeight; if(pucDataStart != 0) { pucData = pucDataStart++; } vDLCD_iReadColumn_Exe(uiStartX, pucDLCD_iRAMBuffer); pucBuffer = &pucDLCD_iRAMBuffer[ucStartY>>3]; for(;;) { if(ucXPageMaxBits >= ucHeightTemp) { ucMask = (ucMask+(0xFF << (ucXStartOff+ucHeightTemp))); ucXPageRemBits = 0; ucHeightTemp = 0; } else { ucXPageRemBits = (ucHeightTemp-ucXPageMaxBits); if(ucXPageRemBits > (8-ucXPageMaxBits)) { ucXPageRemBits = (8-ucXPageMaxBits); } ucHeightTemp -= ucXPageMaxBits; ucHeightTemp -= ucXPageRemBits; } if(pucData != 0) { *pucBuffer &= ucMask; if(ucDrawMode == 0) { *pucBuffer |= ((*pucData<<ucXStartOff) & (~ucMask)); } else { *pucBuffer |= (((~*pucData)<<ucXStartOff) & (~ucMask)); } } else { if(ucDrawMode == DucPLCD_eDispModeReversePlot) { *pucBuffer &= ucMask; } else if(ucDrawMode == DucPLCD_eDispModeNormalPlot) { *pucBuffer |= ~ucMask; } else { /* ** Request is for Reverse Video.. */ ucTempData = ((*pucBuffer) & ucMask); *pucBuffer = (ucTempData | ((~*pucBuffer) & ~ucMask)); } } pucBuffer++; if(ucXPageRemBits != 0) { if(pucData != 0) { *pucBuffer &= ~ucDLCDMask[ucXPageRemBits]; if(ucDrawMode == 0) { *pucBuffer |= (*pucData>>(ucXPageMaxBits)); } else { *pucBuffer |= (((~*pucData)>>ucXPageMaxBits) & ucDLCDMask[ucXPageRemBits]); } } else { if(ucDrawMode == DucPLCD_eDispModeReversePlot) { //*pucBuffer &= ~ucDLCDMask[ucXPageRemBits]; *pucBuffer &= ~ucMask; } else if(ucDrawMode == DucPLCD_eDispModeNormalPlot) { //*pucBuffer |= ~ucDLCDMask[ucXPageRemBits]; *pucBuffer |= ucMask; } else { /* ** Request is for Reverse Video.. */ ucTempData = ((*pucBuffer) & (~ucDLCDMask[ucXPageRemBits])); *pucBuffer = (ucTempData | ((~*pucBuffer) & ucDLCDMask[ucXPageRemBits])); } } } if(ucHeightTemp != 0) { if(pucData != 0) { pucData = &pucData[uiWidth]; } } else { break; } } vDLCD_iWriteColumn_Exe(uiStartX, pucDLCD_iRAMBuffer); uiStartX++; } if(uiStartX >= DucDLCD_eWIDTHSCREEN) { return(DucDLCD_eWIDTHSCREEN-1); } return(uiStartX); } return(DucPLCD_OUT_CONDITIONS); } 当y坐标是8的倍数的时候显示是调用这个函数的 unsigned char ucPLCD_eDisplayAreaAligned_Exe(unsigned int uiStartX, unsigned char ucStartY, \ unsigned int uiWidth, unsigned char ucHeight, \ unsigned char const * pucDataStart, unsigned char ucDrawMode ) { unsigned int uiNextX; unsigned int ucNBColoumn; unsigned char ucMask; if(ucStartY < DucDLCD_eHEIGHTSCREEN) { uiNextX = (uiStartX+uiWidth); if(uiNextX > DucDLCD_eWIDTHSCREEN) { uiNextX = DucDLCD_eWIDTHSCREEN; uiWidth = (DucDLCD_eWIDTHSCREEN-uiStartX); } ucHeight >>= 3; ucStartY >>= 3; vDLCD_eSendCommand_Exe(DucDLCD_iStartLineSetCmd); vDLCD_eSendData_Exe(0x00); while(ucHeight) { vDLCD_eSendCommand_Exe(DucDLCD_iDispDataDirColoumn); vDLCD_eSendCommand_Exe(DucDLCD_iPageAddrSetCmd); vDLCD_eSendData_Exe(ucStartY++); vDLCD_eSendCommand_Exe(DucDLCD_iColmnAddrSetCmd); vDLCD_eSendData_Exe(uiStartX); vDLCD_eSendCommand_Exe(DucDLCD_iDisplayDataWrite); ucNBColoumn = uiWidth; while(ucNBColoumn) { if(ucDrawMode == DucPLCD_eDispModeNormalPlot) { if(pucDataStart != 0) { //pucDataStart = pucDataStart&mask; vDLCD_eSendData_Exe(*pucDataStart); pucDataStart++; } else { vDLCD_eSendData_Exe(0xFF); } } else { if(pucDataStart != 0) { vDLCD_eSendData_Exe(~*pucDataStart); pucDataStart++; } else { vDLCD_eSendData_Exe(0x00); } } ucNBColoumn--; } ucHeight--; } if(uiNextX >= DucDLCD_eWIDTHSCREEN) { return(DucDLCD_eWIDTHSCREEN-1); } return(uiNextX); } return(DucPLCD_OUT_CONDITIONS); }
