DSP怎么向串口发送数据呢?
DSP怎么向串口发送数据呢?
DSP怎么向串口发送数据呢?比如我想发送一个变量last_ad_result的具体值,我用语句
while(SciaRegs.SCIFFRX.bit.RXFFST !=1) { }
      ReceivedChar = SciaRegs.SCIRXBUF.all;
       msg = "  The temperature is:last_ad_result\0";
       scia_msg(msg);
       i = 0;
    while(msg != '\0')
        scia_xmit(msg);
        i++;
void scia_xmit(int a)
    while (SciaRegs.SCIFFTX.bit.TXFFST != 0) {}
    SciaRegs.SCITXBUF=a;
但是用串口助手显示的是The temperature is:last_ad_result啊,而不是The temperature is:某个数值啊
本主题由 A670521546 于 昨天 10:09 审核通过
