1.首先要安装libusb-dev这个库,执行“sudo apt-get install libusb-dev”,装完之后就编译一个下载工具,网上有个牛人提供了一个。代码如下:
CODE:
* dnw.c linux main file. This depends on libusb.
* Author: Fox <hulifox008@163.com>
* License: GPL
#include <stdio.h>
#include <usb.h>
#include <errno.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#define QQ2440_SECBULK_IDVENDOR 0x5345
#define QQ2440_SECBULK_IDPRODUCT 0x1234
struct usb_dev_handle * open_port()
struct usb_bus *busses, *bus;
usb_init();
usb_find_busses();
usb_find_devices();
busses = usb_get_busses();
for(bus=busses;bus;bus=bus->next)
struct usb_device *dev;
for(dev=bus->devices;dev;dev=dev->next)
printf(“idVendor:0x%x\t,ipProduct:0x%x\n”,dev->descriptor.idVendor,dev->descriptor.idProduct);
if( QQ2440_SECBULK_IDVENDOR==dev->descriptor.idVendor&& QQ2440_SECBULK_IDPRODUCT==dev->descriptor.idProduct)
printf(“Target usb device found!\n”);
struct usb_dev_handle *hdev = usb_open(dev);
if(!hdev)
perror(“Cannot open device”);
else
if(0!=usb_claim_interface(hdev, 0))
perror(“Cannot claim interface”);
usb_close(hdev);
hdev = NULL;
return hdev;
printf(“Target usb device not found!\n”);
return NULL;
void usage(void)
printf(“Usage: dnw <file>\n\n”);
unsigned char* prepare_write_buf(char *filename, unsigned int *len)
unsigned char *write_buf = NULL;
struct stat fs;
int fd = open(filename, O_RDONLY);
if(-1==fd)
perror(“Cannot open file”);
return NULL;
if(-1==fstat(fd, &fs))
perror(“Cannot get file size”);
goto error;
write_buf = (unsigned char*)malloc(fs.st_size+10);
if(NULL==write_buf)
perror(“malloc failed”);
goto error;
if(fs.st_size != read(fd, write_buf+8, fs.st_size))
perror(“Reading file failed”);
goto error;
printf(“Filename : %s\n”, filename);
printf(“Filesize : %d bytes\n”, fs.st_size);
*((u_int32_t*)write_buf) = 0x30000000; //download address
*((u_int32_t*)write_buf+1) = fs.st_size + 10; //download size;
*len = fs.st_size + 10;
return write_buf;
error:
if(fd!=-1)
close(fd);
if(NULL!=write_buf)
free(write_buf);
fs.st_size = 0;
return NULL;
int main(int argc, char *argv[])
if(2!=argc)
usage();
return 1;
struct usb_dev_handle *hdev = open_port();
if(!hdev)
return 1;
unsigned int len = 0;
unsigned char* write_buf = prepare_write_buf(argv[1], &len);
if(NULL==write_buf)
return 1;
unsigned int remain = len;
unsigned int towrite;
printf(“Writing data …\n”);
while(remain)
towrite = remain>512 ? 512 : remain;
if(towrite != usb_bulk_write(hdev, 0x03, write_buf+(len-remain), towrite, 3000))
perror(“usb_bulk_write failed”);
break;
remain-=towrite;
printf(“\r%d%\t %d bytes ”, (len-remain)*100/len, len-remain);
fflush(stdout);
if(0==remain)
printf(“Done!\n”);
return 0;
2.把它保存为文件dnw.c,编译“gcc dnw2.c -o dnw -lusb”,编译完得到的dnw就是usb下载的PC端了。下载时用“dnw <filename>”下载文件到板上。也可生成的链接文件“sudo ln -s ./dnw /usr/sbin/dnw”,这样在编译完要下载文件就可以直接下载了。 |
