问:请问各位高手,如何计算你的片子用的门数呀?
回答1:一般来说,FPGA/CPLD说的是用了多少CLB或slice,具体的门数只是个估计值,我是这么看的。在ISE中实现后,会有Map Report和Post P&R Static Timing Report,你只要看Map Report中的信息就可以了,比如我的设计给出的Map Report是这样的: Number of errors: 0 Number of warnings: 5 Logic Utilization: Number of Slice Flip Flops: 1,278 out of 3,072 41% Number of 4 input LUTs: 1,172 out of 3,072 38% Logic Distribution: Number of occupied Slices: 959 out of 1,536 62% Number of Slices containing only related logic: 959 out of 959 100% Number of Slices containing unrelated logic: 0 out of 959 0% *See NOTES below for an explanation of the effects of unrelated logic Total Number 4 input LUTs: 1,237 out of 3,072 40% Number used as logic: 1,172 Number used as a route-thru: 65 Number of bonded IOBs: 40 out of 92 43% IOB Flip Flops: 1 Number of Block RAMs: 6 out of 24 25% Number of GCLKs: 3 out of 16 18% Total equivalent gate count for design: 414,573 //这就是门数 Additional JTAG gate count for IOBs: 1,920 Peak Memory Usage: 86 MB |
