串口输出信息是这样的,这个是什么问题?硬件有问题吗
U-Boot 1.1.6 rel-4-3-10 (Dec 13 2011 - 05:11:31) for SMDK2416
CPU:   S3C2416@400MHz
       Fclk = 800MHz, Hclk = 133MHz, Pclk = 66MHz
Board: SMDK2416 DDR2
DRAM:    64 MB
Flash:   0 kB
NAND:    32 MB
SD/MMC:  nfconf = 80007774
In:      serial
Out:     serial
Err:     serial
Net:     ax88796c
Warning: ax88796c MAC addresses don't match:
Address in SROM is         08:00:3E:26:0A:5B
Address in environment is  00:40:5C:26:0A:5B
Hit any key to stop autoboot:  3
NAND read: device 0 offset 0x1f00000, size 0x4b000
307200 bytes read: OK
NAND read: device 0 offset 0x100000, size 0x200000
2097152 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux............................................................ |
