[求助] 编译有些警告,看不懂,那位高手指点下!
Warning : C1020: Incompatible type to previous declaration (found 'void *(*) (void (*)(void *),void *,unsigned char *,unsigned int )',
expected 'unsigned char *(*) (void (*)(void *),void *,unsigned char *,unsigned int )')
OS_CPU_C.C line 11
C1440: This is causing previous message 1020
ucos_ii.h line 823
Warning : C1825: Indirection to different types ('unsigned char *' instead of 'unsigned int *')
OS_CPU_C.C line 14
Warning : C5917: Removed dead assignment
OS_CPU_C.C line 15
Warning : C4200: Other segment than in previous declaration
OS_CPU_C.C line 40
C12053: Stack-pointer change not in debugging-information
OS_CPU_C.C line 62
OS_CPU_C.C line 81
OS_CPU_C.C line 92
OS_CPU_C.C line 114
OS_CPU_C.C line 173
OS_CPU_C.C line 192
OS_CPU_C.C line 268
L1923: File G:\s12\S12\S12_Data\Simulator\ObjectCode\OS_FLAG.C.o has no DWARF debug info
L1923: File G:\s12\S12\S12_Data\Simulator\ObjectCode\OS_SEM.C.o has no DWARF debug info
L1923: File G:\s12\S12\S12_Data\Simulator\ObjectCode\OS_TASK.C.o has no DWARF debug info
L1923: File G:\s12\S12\S12_Data\Simulator\ObjectCode\OS_TIME.C.o has no DWARF debug info
L1923: File G:\s12\S12\S12_Data\Simulator\ObjectCode\OS_CORE.C.o has no DWARF debug info
L1923: File G:\s12\S12\S12_Data\Simulator\ObjectCode\OS_CPU_C.C.o has no DWARF debug info
多多指教!!
一下子帖这么多啊,C开头的警告有的是没有引用头文件,函数原型找不到,有的是定义有重复。
L1923是没有加入调试信息,你把对应的C文件后的最后一栏有个绿色小甲虫的地方点上黑点
