page_cache_get(old_page); pte_unmap_unlock(page_table, ptl);
tmp = vma->vm_ops->page_mkwrite(vma, &vmf);
if (unlikely(tmp &
(VM_FAULT_ERROR | VM_FAULT_NOPAGE))) {
ret = tmp;
goto unwritable_page;
if (unlikely(!(tmp & VM_FAULT_LOCKED))) {
lock_page(old_page);
if (!old_page->mapping) {
ret = 0; /* retry the fault */
unlock_page(old_page);
} else
VM_BUG_ON(!PageLocked(old_page));
* Since we dropped the lock we need to revalidate
* the PTE as someone else may have changed it. If
* they did, we just return, as we can count on the
* MMU to tell us if they didn't also make it writable.
page_table = pte_offset_map_lock(mm, pmd, address,
&ptl);
if (!pte_same(*page_table, orig_pte)) {
page_cache_release(old_page);
goto unlock;
page_mkwrite = 1;
dirty_page = old_page;
get_page(dirty_page);
reuse = 1;
/*reuse: 不进行COW,直接操作该页old_page*/
if (reuse) {
reuse:
flush_cache_page(vma, address, pte_pfn(orig_pte));
entry = pte_mkyoung(orig_pte);
/*写该页的二级页表属性,加入可写且脏*/
entry = maybe_mkwrite(pte_mkdirty(entry), vma);
if (ptep_set_access_flags(vma, address, page_table, entry,1))
update_mmu_cache(vma, address, entry);
ret |= VM_FAULT_WRITE;
goto unlock;
* Ok, we need to copy. Oh, well..
/*真正的COW即将开始*/
/*首先增加之前的页的被映射次数(get_page(), page->_count)*/
gotten:
if (unlikely(anon_vma_prepare(vma)))
goto oom;
/*COW的第一种情况(zero_pfn),将分配新页并清零该页*/
if (is_zero_pfn(pte_pfn(orig_pte))) {
new_page = alloc_zeroed_user_highpage_movable(vma, address);
if (!new_page)
goto oom;
/*COW的第二种情况(fork),申请一个页,并把old_page页的内容拷贝到新页new_page(4K字节的内容)*/
else {
new_page = alloc_page_vma(GFP_HIGHUSER_MOVABLE, vma, address);
if (!new_page)
goto oom;
cow_user_page(new_page, old_page, address, vma);
__SetPageUptodate(new_page);
* Don't let another task, with possibly unlocked vma,
* keep the mlocked page.
/*COW第二种情况下,如果vma还是锁定的,那还需要解锁*/
if ((vma->vm_flags & VM_LOCKED) && old_page) {
lock_page(old_page); /* for LRU manipulation */
clear_page_mlock(old_page);
/*空函数*/
if (mem_cgroup_newpage_charge(new_page, mm, GFP_KERNEL))
goto oom_free_new;
* Re-check the pte - we dropped the lock
