四、相关库函数解析
1、库中所涉及到的结构体
typedef struct
uint32_t SYSCLK_Frequency;
/*!< returns SYSCLK clock frequency expressed in Hz */
uint32_t HCLK_Frequency;
/*!< returns HCLK clock frequency expressed in Hz */
uint32_t PCLK1_Frequency;
/*!< returns PCLK1 clock frequency expressed in Hz */
uint32_t PCLK2_Frequency;
/*!< returns PCLK2 clock frequency expressed in Hz */
uint32_t ADCCLK_Frequency; /*!< returns ADCCLK clock frequency expressed in Hz */
}RCC_ClocksTypeDef;
2、库函数解析
void RCC_DeInit(void);//将外设RCC寄存器设为缺省值;(除RCC_BDCR和RCC_CSR)
void RCC_HSEConfig(uint32_t RCC_HSE);//设置外部高速晶振(HSE);
//输入:RCC_HSE_OFF,RCC_HSE_ON,RCC_HSE_Bypass(HSE旁路)
ErrorStatus RCC_WaitForHSEStartUp(void);//等待HSE起振;
//返回值:SUCCESS,HSE晶振稳定且就绪;ERROR,HSE晶振未就绪
void RCC_AdjustHSICalibrationValue(uint8_t HSICalibrationValue);//调整内部高速晶振(HSI)校准值
//输入:校准补偿值(该参数取值必须在0到0x1F之间)
void RCC_HSICmd(FunctionalState NewState);//使能或者失能内部高速晶振(HSI)
//输入:ENABLE或者DISABLE(如果HSI被用于系统时钟,或者FLASH编写操作进行中,那么它不能被停振)
void RCC_PLLConfig(uint32_t RCC_PLLSource, uint32_t RCC_PLLMul);//设置PLL时钟源及倍频系数
//输入:RCC_PLLSource_HSI_Div2,RCC_PLLSource_HSE_Div1,RCC_PLLSource_HSE_Div2
//输入:RCC_PLLMul_2到RCC_PLLMul_16
void RCC_PLLCmd(FunctionalState NewState);// 使能或者失能PLL
#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL) || defined (STM32F10X_CL)
void RCC_PREDIV1Config(uint32_t RCC_PREDIV1_Source, uint32_t RCC_PREDIV1_Div);//
#endif
#ifdef
STM32F10X_CL
void RCC_PREDIV2Config(uint32_t RCC_PREDIV2_Div);//
void RCC_PLL2Config(uint32_t RCC_PLL2Mul);//
void RCC_PLL2Cmd(FunctionalState NewState);//
void RCC_PLL3Config(uint32_t RCC_PLL3Mul);//
void RCC_PLL3Cmd(FunctionalState NewState);//
#endif /* STM32F10X_CL */
void RCC_SYSCLKConfig(uint32_t RCC_SYSCLKSource);//设置系统时钟(SYSCLK)源
// RCC_SYSCLKSource_HSI,RCC_SYSCLKSource_HSE,RCC_SYSCLKSource_PLLCLK
uint8_t RCC_GetSYSCLKSource(void);// 返回用作系统时钟的时钟源
//返回值:0x00 HSI作为系统时钟,0x04 HSE作为系统时钟,0x08 PLL作为系统时钟
void RCC_HCLKConfig(uint32_t RCC_SYSCLK);//设置AHB时钟(HCLK)
//输入:RCC_SYSCLK_Div1,RCC_SYSCLK_Div2,RCC_SYSCLK_Div4,RCC_SYSCLK_Div8,RCC_SYSCLK_Div16,
//RCC_SYSCLK_Div32,RCC_SYSCLK_Div64,RCC_SYSCLK_Div128,RCC_SYSCLK_Div256,RCC_SYSCLK_Div512
void RCC_PCLK1Config(uint32_t RCC_HCLK);//
设置低速AHB时钟(PCLK1)
//输入: RCC_HCLK_Div1, RCC_HCLK_Div2, RCC_HCLK_Div4, RCC_HCLK_Div8, RCC_HCLK_Div16
void RCC_PCLK2Config(uint32_t RCC_HCLK);// 设置高速AHB时钟(PCLK2)
//输入:RCC_HCLK_Div1, RCC_HCLK_Div2, RCC_HCLK_Div4, RCC_HCLK_Div8, RCC_HCLK_Div16
void RCC_ITConfig(uint8_t RCC_IT, FunctionalState NewState);// 使能或者失能指定的RCC中断
//输入:RCC_IT_LSIRDY
LSI就绪中断->ENABLE或者DISABLE
//RCC_IT_LSERDY
LSE就绪中断,RCC_IT_HSIRDY
HSI就绪中断
//RCC_IT_HSERDY
HSE就绪中断,RCC_IT_PLLRDY
PLL就绪中断
#ifndef STM32F10X_CL
void RCC_USBCLKConfig(uint32_t RCC_USBCLKSource);// 设置USB时钟(USBCLK)
//输入:RCC_USBCLKSource_PLLCLK_1Div5,USB时钟 = PLL时钟除以1.5
RCC_USBCLKSource_PLLCLK_Div1,USB时钟 = PLL时钟
#else
void RCC_OTGFSCLKConfig(uint32_t RCC_OTGFSCLKSource);//
void RCC_ADCCLKConfig(uint32_t RCC_PCLK2);//
设置ADC时钟(ADCCLK)
//RCC_PCLK2_Div2,ADC时钟 = PCLK / 2;RCC_PCLK2_Div4,ADC时钟 = PCLK / 4;
//RCC_PCLK2_Div6,ADC时钟 = PCLK / 6;RCC_PCLK2_Div8,ADC时钟 = PCLK / 8
#ifdef STM32F10X_CL
void RCC_I2S2CLKConfig(uint32_t RCC_I2S2CLKSource); //
void RCC_I2S3CLKConfig(uint32_t RCC_I2S3CLKSource);//
void RCC_LSEConfig(uint8_t RCC_LSE);// 设置外部低速晶振(LSE)
//输入:RCC_LSE_OFF,LSE晶振OFF;RCC_LSE_ON,LSE晶振ON;
//RCC_LSE_Bypass,LSE晶振被外部时钟旁路
void RCC_LSICmd(FunctionalState NewState);// 使能或者失能内部低速晶振(LSI)
(IWDG运行的话,LSI不能被失能)
void RCC_RTCCLKConfig(uint32_t RCC_RTCCLKSource);//设置RTC时钟(RTCCLK)源(RTC时钟一经选定即不能更改,除非复位后备域)
//输入:RCC_RTCCLKSource_LSE,选择LSE作为RTC时钟;RCC_RTCCLKSource_LSI,选择LSI作为RTC时钟;RCC_RTCCLKSource_HSE_Div128,选择HSE时钟频率除以128作为RTC时钟
void RCC_RTCCLKCmd(FunctionalState NewState);// 使能或者失能RTC时钟
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks);// 返回时钟的频率
//输入:指向结构RCC_ClocksTypeDef的指针,包含了各个时钟的频率(单位为Hz)
