STM32的时钟系统RCC详细整理(8)
五、实例详解
#if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)//如果定义了这些系统时钟将设为24M,如果没有定义则为72M
/* #define SYSCLK_FREQ_HSE    HSE_VALUE */
#define SYSCLK_FREQ_24MHz  24000000
#else
/* #define SYSCLK_FREQ_24MHz  24000000 */
/* #define SYSCLK_FREQ_36MHz  36000000 */
/* #define SYSCLK_FREQ_48MHz  48000000 */
/* #define SYSCLK_FREQ_56MHz  56000000 */
#define SYSCLK_FREQ_72MHz  72000000      //系统时钟默认值的定义
,如果没有定义外部高速时钟则用内部高速时钟,为8000000
/*只需修改以上几句就可以自动设置使用外部倍频作为系统时钟,如果以上宏都未定义则在下边把内部高速时钟作为系统时钟*/
#endif
/*!< Uncomment the following line if you need to use external SRAM mounted
     on STM3210E-EVAL board (STM32 High density and XL-density devices) or on
     STM32100E-EVAL board (STM32 High-density value line devices) as data memory */
#if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)//
内外部SRAM选择
/* #define DATA_IN_ExtSRAM */
#endif
/*!< Uncomment the following line if you need to relocate your vector Table in
     Internal SRAM. */
/* #define VECT_TAB_SRAM */
#define VECT_TAB_OFFSET  0x0 /*!< Vector Table base offset field. //
向量表的基址偏移量
                                  This value must be a multiple of 0x100. */
*  Clock Definitions;
以下为把系统时钟的定义值传给系统内核时钟变量,如果没有定义外部高速时钟则用内部高速时钟,为8M
#ifdef SYSCLK_FREQ_HSE
  uint32_t SystemCoreClock         = SYSCLK_FREQ_HSE;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_24MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_36MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_36MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_48MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_56MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_56MHz;        /*!< System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_72MHz
  uint32_t SystemCoreClock         = SYSCLK_FREQ_72MHz;        /*!< System Clock Frequency (Core Clock) */
#else /*!< HSI Selected as System Clock source */
  uint32_t SystemCoreClock         = HSI_VALUE;        /*!< System Clock Frequency (Core Clock)
如果没有定义外部高速时钟则用内部高速时钟,为8000000*/
#endif
__I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};//AHB配方表
/** @addtogroup STM32F10x_System_Private_FunctionPrototypes
以下为函数声明
static void SetSysClock(void); //设置系统时钟的函数声明
//以下为根据不同的系统时钟的定义来声明用到的相应的函数,为后面的函数调用做好准备
  static void SetSysClockToHSE(void);
  static void SetSysClockTo24(void);
  static void SetSysClockTo36(void);
  static void SetSysClockTo48(void);
  static void SetSysClockTo56(void);
  static void SetSysClockTo72(void);
#endif
#ifdef DATA_IN_ExtSRAM //外部SRAM选择后的初始化函数声明
  static void SystemInit_ExtMemCtl(void);
#endif /* DATA_IN_ExtSRAM */
继承事业,薪火相传
