[求助]Protel99SE中的错误
[求助]Protel99SE中的错误
想用Protel 按层次电路的方式设计一个板子,出现了下面的错误。fficeffice" />
呵呵 问一下那些相同的是什么意思啊?
 #1 Error   Duplicate Sheet Numbers 0 DLB.prj And POWER.sch
 #2 Error   Duplicate Sheet Numbers 0 DLB.prj And LPC.sch
 #3 Error   Duplicate Sheet Numbers 0 DLB.prj And RES.sch
 #4 Error   Duplicate Sheet Numbers 0 DLB.prj And CLC.sch
 #5 Error   Duplicate Sheet Numbers 0 DLB.prj And URT.sch
 #6 Error   Duplicate Sheet Numbers 0 DLB.prj And EXT.sch
 #7 Error   Duplicate Sheet Numbers 0 DLB.prj And JTAG.sch
 #8 Error   Duplicate Sheet Numbers 0 POWER.sch And LPC.sch
 #9 Error   Duplicate Sheet Numbers 0 POWER.sch And RES.sch
 #10 Error   Duplicate Sheet Numbers 0 POWER.sch And CLC.sch
 #11 Error   Duplicate Sheet Numbers 0 POWER.sch And URT.sch
 #12 Error   Duplicate Sheet Numbers 0 POWER.sch And EXT.sch
 #13 Error   Duplicate Sheet Numbers 0 POWER.sch And JTAG.sch
 #14 Error   Duplicate Sheet Numbers 0 LPC.sch And RES.sch
 #15 Error   Duplicate Sheet Numbers 0 LPC.sch And CLC.sch
 #16 Error   Duplicate Sheet Numbers 0 LPC.sch And URT.sch
 #17 Error   Duplicate Sheet Numbers 0 LPC.sch And EXT.sch
 #18 Error   Duplicate Sheet Numbers 0 LPC.sch And JTAG.sch
 #19 Error   Duplicate Sheet Numbers 0 RES.sch And CLC.sch
 #20 Error   Duplicate Sheet Numbers 0 RES.sch And URT.sch
 #21 Error   Duplicate Sheet Numbers 0 RES.sch And EXT.sch
 #22 Error   Duplicate Sheet Numbers 0 RES.sch And JTAG.sch
 #23 Error   Duplicate Sheet Numbers 0 CLC.sch And URT.sch
 #24 Error   Duplicate Sheet Numbers 0 CLC.sch And EXT.sch
 #25 Error   Duplicate Sheet Numbers 0 CLC.sch And JTAG.sch
 #26 Error   Duplicate Sheet Numbers 0 URT.sch And EXT.sch
 #27 Error   Duplicate Sheet Numbers 0 URT.sch And JTAG.sch
 #28 Error   Duplicate Sheet Numbers 0 EXT.sch And JTAG.sch
 #29 Error  HiZ Pins And Power Pins On Net GND
   HiZ Pins                 : URT.sch(U5-11
450,410) URT.sch(U6-11 900,410)
   Power Pins               : RES.sch(U5-7
660,350) RES.sch(U6-7 790,350)
 #30 Warning   Unconnected Input Pin On Net NetU5_14
   URT.sch(U5-14
320,410)
 #32 Error   Floating Input Pins On Net NetU5_14
Pin URT.sch(U5-14
320,410)
 #33 Warning   Unconnected Input Pin On Net NetU6_14
   URT.sch(U6-14
770,410)
 #35 Error   Floating Input Pins On Net NetU6_14
Pin URT.sch(U6-14
770,410)
日初,整装而发;日暮,满载而归。
你几张原理图的 编号一样,你需要在DESIGN---OPTION--ORGNIZATION 那里,有个
TOTAL 和 SHEET
你把它改成不同的就行了
51 c8051f(f020,f040) msp430 arm(2410,2510) fpga(xc3s4000) dsp(5116 dm642) keilc vc++ matlab linux protel Ten_layerPCB mpegx h.26x Rscode Turbocode ofdm VideoBroadcasting ldpc_code(now!)
需要设置原理图的图纸编号,设置方法也可以是:在原理图的方框外部,白色区域点右键,在属性里设置!在层次原理图中,图纸号不能重复!
[此贴子已经被linuxarm于2006-4-24 17:41:06编辑过]
哦 原来是这样 非常感谢!
日初,整装而发;日暮,满载而归。
我也请教一下?Protel99se里面如何把几张原理图纸合成一个网络表,还有前提是要先设置哪些比仿说图纸编号?谢谢!
老虎不发威,你以为我是Hello Kitty
在生成网络表的时候,再弹出的“Netlist Creation”对话框的第三个下拉菜(Sheets To Netlist)中,你选Active project,就能把整个project中的图纸都放在一个网络表中le
如果选Active sheet,则只是将当前的原理图生成网络表
谢linuxarm,我知道了!!!
很高兴你提的问题我能回答上
呵呵
