Tomato-ARM部署ShadowSocks科学上网(2)
8.设置透明代理和UDP转发脚本并加入自动启动选项
1 | root@unknown:/# /jffs/shadowsocks set_up |
shadowsocks部分脚本
02 | sed -e "s/shadowsocks.json\"/shadowsocks.json\"/" -e "s/PROCS=ss-local/PROCS=ss-redir/" -i /opt/etc/init.d/S22shadowsocks |
03 | # sed -e "s/shadowsocks.json\"/shadowsocks.json -b 0.0.0.0 -l 5300 -L 8.8.8.8:53 -u\"/" -e "s/PROCS=ss-redir/PROCS=ss-tunnel/" /opt/etc/init.d/S22shadowsocks > /opt/etc/init.d/S23ss-tunnel |
04 | sed '4c PROCS=chinadns' /opt/etc/init.d/S22shadowsocks > /opt/etc/init.d/S24cn |
05 | # sed '5c ARGS="-b 127.0.0.1 -p 5353 -c /opt/etc/chnroute.txt -s 114.114.114.114,208.67.222.222:443,8.8.8.8:53"' /opt/etc/init.d/S24cn > /opt/etc/init.d/S24chinadns |
06 | # sed '5c ARGS="-b 127.0.0.1 -p 5353 -c /opt/etc/chnroute.txt -s 114.114.114.114,127.0.0.1:5300"' /opt/etc/init.d/S24cn > /opt/etc/init.d/S24chinadns |
08 | rm -f /opt/etc/init.d/S24cn |
09 | chmod +x /opt/etc/init.d/S2* |
加入自动启动init选项,Administration >> Scripts >> init选项写入/jffs/shadowsocks run
9.配置加载防火墙策略和加载ipset内核模块脚本(具有jffs)
说明!前几次更新都是利用gfwlist来通过dnsmasq解析出来IP加入到ipset集合中,但这次更新直接用chnroutes来导入中国IP段来判断。
集成多个子脚本shadowsocks
005 | # This program is distributed in the hope that it will be useful, |
006 | # but WITHOUT ANY WARRANTY; without even the implied warranty of |
007 | # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the |
008 | # GNU General Public License for more details. |
010 | # You should have received a copy of the GNU General Public License |
011 | # along with this program; if not, write to the Free Software |
016 | sed -e "s/shadowsocks.json\"/shadowsocks.json\"/" -e "s/PROCS=ss-local/PROCS=ss-redir/" -i /opt/etc/init.d/S22shadowsocks |
017 | # sed -e "s/shadowsocks.json\"/shadowsocks.json -b 0.0.0.0 -l 5300 -L 8.8.8.8:53 -u\"/" -e "s/PROCS=ss-redir/PROCS=ss-tunnel/" /opt/etc/init.d/S22shadowsocks > /opt/etc/init.d/S23ss-tunnel |
018 | sed '4c PROCS=chinadns' /opt/etc/init.d/S22shadowsocks > /opt/etc/init.d/S24cn |
019 | # sed '5c ARGS="-b 127.0.0.1 -p 5353 -c /opt/etc/chnroute.txt -s 114.114.114.114,208.67.222.222:443,8.8.8.8:53"' /opt/etc/init.d/S24cn > /opt/etc/init.d/S24chinadns |
020 | # sed '5c ARGS="-b 127.0.0.1 -p 5353 -c /opt/etc/chnroute.txt -s 114.114.114.114,127.0.0.1:5300"' /opt/etc/init.d/S24cn > /opt/etc/init.d/S24chinadns |
022 | cat /etc/resolv.dnsmasq | awk '/^nameserver/{print $2}' > /jffs/dns.list |
023 | DNS=`sed -n '1p' /jffs/dns.list` |
024 | sed -i "s/^ARGS=\(.*\)114.114.114.114\(.*\)$/ARGS=\1$DNS\2/" /opt/etc/init.d/S24chinadns |
026 | rm -f /opt/etc/init.d/S24cn |
027 | chmod +x /opt/etc/init.d/S2* |
031 | /opt/etc/init.d/S22shadowsocks start |
033 | # /opt/etc/init.d/S23ss-tunnel start |
034 | /opt/etc/init.d/S24chinadns start |
038 | CHAIN=`lsmod | grep -i xt_set` |
039 | _input=/jffs/ignore.list |
043 | for module in ip_set ip_set_bitmap_ip ip_set_bitmap_ipmac ip_set_bitmap_port ip_set_hash_ip ip_set_hash_ipport ip_set_hash_ipportip ip_set_hash_ipportnet ip_set_hash_net ip_set_hash_netport ip_set_list_set xt_set |
049 | ipset -N ss_spec_lan_ac hash:net |
050 | sed -e "s/^/-A ss_spec_wan_ac &/g" -e "1 i\-N ss_spec_wan_ac hash:net " $_input | ipset -R -! |
054 | SS=`sed -n 's/.*ver":"\(.*\)".*/\1/p' /opt/etc/shadowsocks.json` |
056 | iptables -t nat -N SS_SPEC_WAN_AC |
057 | iptables -t nat -N SS_SPEC_WAN_FW |
058 | iptables -t nat -A SS_SPEC_WAN_AC -d $SS -j RETURN |
059 | iptables -t nat -A SS_SPEC_WAN_AC -m set --match-set ss_spec_wan_ac dst -j RETURN |
060 | iptables -t nat -A SS_SPEC_WAN_AC -j SS_SPEC_WAN_FW |
061 | iptables -t nat -A SS_SPEC_WAN_FW -p tcp -j REDIRECT --to-ports 1080 |
062 | iptables -t nat -A PREROUTING -p tcp -m multiport --dports 22,80,443 -m set ! --match-set ss_spec_lan_ac src -j SS_SPEC_WAN_AC |
063 | iptables -t nat -A OUTPUT -p tcp -m multiport --dports 22,80,443 -j SS_SPEC_WAN_AC |
