2) 任务级任务切换
任务级任务切换函数OS_TasK_Sw()是当前任务因为被阻塞而主动请求CPU高度时被执行的,由于此时的任务切换都是在非异常模式直进行的,因此区别于中断级别的任务切换。它的工作是先将当前任务的CPU现场保存到该任务的堆栈中,然后获得最高优先级任务的堆栈指针,从该堆栈中恢复此任务的CPU现场,使之继续运行,从而完成任务切换。
OSCtxSw
; SAVE CURRENT TASK'S CONTEXT
STMFD SP!, {LR} ; Push return address
STMFD SP!, {LR}
STMFD SP!, {R0-R12} ; Push registers
MRS R4, CPSR ; Push current CPSR
TST LR, #1 ; See if called from Thumb mode
ORRNE R4, R4, #0x20 ; If yes, Set the T-bit
STMFD SP!, {R4}
LDR R4, OS_TCBCur ; OSTCBCur->OSTCBStkPtr = SP;
LDR R5, [R4]
STR SP, [R5]
LDR R0, OS_TaskSwHook ; OSTaskSwHook();
MOV LR, PC
BX R0
LDR R4, OS_PrioCur ; OSPrioCur = OSPrioHighRdy
LDR R5, OS_PrioHighRdy
LDRB R6, [R5]
STRB R6, [R4]
LDR R4, OS_TCBCur ; OSTCBCur = OSTCBHighRdy;
LDR R6, OS_TCBHighRdy
LDR R6, [R6]
STR R6, [R4]
LDR SP, [R6] ; SP = OSTCBHighRdy->OSTCBStkPtr;
;STORE NEW TASK'S CONTEXT
LDMFD SP!, {R4} ; Pop new task's CPSR
MSR SPSR_cxsf, R4
LDMFD SP!, {R0-R12,LR,PC}^ ; Pop new task's context
3) 中断级任务切换函数
① 该函数由OSIntExit()和OSExIntExit()调用,它若在时钟中断ISR中发现有高优先级任务等特的时候信号到来,则需要在中断退出后并不返回被中断的,的而是直接调度就绪的高高优先级任务执行.这样做的目的主要是能够尽快的让优先级高的任务得到响应,进而保证系统的实时性。
OSIntCtxSw
MOV LR, PC
BX R0
LDRB R6,[R5]
STRB R6,[R4]
LDR R4,OS_TCBCur ; OSTCBCur = OSTCBHighRdy;
LDR R6,OS_TCBHighRdy
LDR R6,[R6]
STR R6,[R4]
LDR SP,[R6] ; SP = OSTCBHighRdy->OSTCBStkPtr;
; RESTORE NEW TASK'S CONTEXT
MSR SPSR_cxsf, R4
② 两种形式的中断程序
OS_CPU_IRQ_ISR
STMFD SP!, {R1-R3} ; PUSH WORKING REGISTERS ONTO IRQ STACK
MOV R1, SP ; Save IRQ stack pointer
ADD SP, SP,#12 ; Adjust IRQ stack pointer
SUB R2, LR,#4 ; Adjust PC for return address to task
MRS R3, SPSR ; Copy SPSR (i.e. interrupted task's CPSR) to R3
MSR CPSR_c, #(NO_INT | SVC32_MODE) ; Change to SVC mode
; SAVE TASK'S CONTEXT ONTO TASK'S STACK
STMFD SP!, {R2} ; Push task's Return PC
STMFD SP!, {LR} ; Push task's LR
STMFD SP!, {R4-R12} ; Push task's R12-R4
LDMFD R1!, {R4-R6} ; Move task's R1-R3 from IRQ stack to SVC stack
STMFD SP!, {R4-R6}
STMFD SP!, {R0} ; Push task's R0 onto task's stack
STMFD SP!, {R3} ; Push task's CPSR (i.e. IRQ's SPSR)
LDR R0, OS_IntNesting ; OSIntNesting++;
LDRB R1, [R0]
ADD R1, R1,#1
STRB R1, [R0]
CMP R1, #1 ; if (OSIntNesting == 1) {
BNE OS_CPU_IRQ_ISR_1
LDR R5, [R4]
STR SP, [R5] ; }
OS_CPU_IRQ_ISR_1
MSR CPSR_c, #(NO_INT | IRQ32_MODE) ; Change to IRQ mode (to use the IRQ stack to handle interrupt)
LDR R0, OS_CPU_IRQ_ISR_Handler ; OS_CPU_IRQ_ISR_Handler();
MOV LR, PC
BX R0
LDR R0, OS_IntExit ; OSIntExit();
MOV LR, PC
BX R0 ; RESTORE NEW TASK'S CONTEXT
MSR SPSR_cxsf, R4
RSEG CODE:CODE:NOROOT(2)
CODE32 |
51 c8051f(f020,f040) msp430 arm(2410,2510) fpga(xc3s4000) dsp(5116 dm642) keilc vc++ matlab linux protel Ten_layerPCB mpegx h.26x Rscode Turbocode ofdm VideoBroadcasting ldpc_code(now!) |
