我们和freescale联系了,他们说烧录空白的芯片需要这个东西,以下是原文
No need for a programmer. What you need is a USB debugging pod from PE and they will also provide the programming GUI for a MicroSoft operating system. CodeWarrior's compiler will generate the S-record and allow for paging configurations as you start your project. The true time debugger will allow you to program and test the program after programming the FLASH array. Once you are finished qualifying all firmware functions then you can simply use the PE Programmer GUI to simply program the FLASH.
