[求助]mc68376编程的问题:不能调用子函数
我刚开始学习32位单片机的编程,mc68376.结果程序不能调用子程序,把子程序的代码写在main()函数里就可以执行.比如我想调用延时子程序:delay()
void delay(void);
void  main(void)
 //系统初始化开始,初始化CPU,外部rom,ram,片选
asm(" ORI.W #$2700,SR");
asm(" MOVEA.L #$111e00,A7");
    SIMCR=0x60CF;
    SYNCR=0x7F00;
     SYPCR=0xD0;
    CSBARBT=0x0003;
    CSBAR0=0x1003;
    CSBAR1=0x1003;
    CSPAR0=0x00FF;
    CSPAR1=0x0000;
    CSORBT=0x68B0;
    CSOR0=0x3830;
    CSOR1=0x5830;
    ICR=0x0446;
    PITR=0x0052;
    PEPAR=0x00;
    DDRE=0x1F;
     PORTE0=0x00;
     FPAR=0x00;
     DDRF=0x00;
     PORTF0=0x00;
     RAMBAH=0x0011;
    RAMBAL=0x0000;
    RAMMCR=0x0A00;//系统初始化结束
delay();//调用子程序,想在这里延时
while(1){
//依次点亮led
PORTC=0x70;
 ORTE0=0x00;
 for(i=0;i<50000;i++)
 asm(" NOP ");
 ORTC=0x68;
 asm(" NOP ");
 ORTC=0x58;
 asm(" NOP ");
    PORTC=0x38;
 asm(" NOP ");
void delay(void)
 asm(" NOP ");
在程序里只要调用delay()函数时程序就不向下执行,停在这个地方.搞不明白这是什么原因?
编译后生成的汇编文件:
_main:
 ?file ./reg.h
 ?endf
 ?file ./vec.h
 ?endf
 ?file C:\MGC\embedded\include\mcc68k/stdlib.h
 ?endf
 ?file C:\MGC\embedded\include\mcc68k/stddef.h
 ?endf
 ?file C:\MGC\embedded\include\mcc68k/string.h
 ?endf
 ?file C:\MGC\embedded\include\mcc68k/float.h
 ?endf
  ORI.W #$2700,SR
  MOVEA.L #$111e00,A7
 move.w #24783,16775680
  move.w #32512,16775684
   clr.b 16775713
  move.w #3,16775752
  move.w #4099,16775756
  move.w #4099,16775760
  move.w #255,16775748
  clr.w 16775750
 move.w #26800,16775754
 move.w #14384,16775758
  move.w #22576,16775762
  clr.b 16775745
 move.w #1094,16775714
 move.w #82,16775716
  clr.b 16775703
  move.b #255,16775701
  clr.b 16775697
  clr.b 16775711
 clr.b 16775709
 clr.b 16775705
 move.w #17,16776004
 clr.w 16776006
 move.w #2560,16776000
 move.w #37824,16775200
 move.w #32899,16773632
move.w #32899,16776192
 move.w #39680,16774144
 move.w #32899,16776704
 move.w #33024,16775936
 move.w #55680,16773248
 jsr _delay
L1:
 move.b #112,16775745
 clr.l _i
 bra.w L5
L4:
 NOP
 addq.l #1,_i
L5:
 cmpi.l #50000,_i
 bcs.s L4
 move.b #104,16775745
 clr.l _i
 bra.w L9
L8:
 NOP
 addq.l #1,_i
L9:
 cmpi.l #50000,_i
 bcs.s L8
 move.b #88,16775745
 clr.l _i
 bra.w L13
L12:
 NOP
 addq.l #1,_i
L13:
 cmpi.l #50000,_i
 bcs.s L12
 move.b #56,16775745
 clr.l _i
 bra.w L17
L16:
 NOP
 addq.l #1,_i
L17:
 cmpi.l #50000,_i
 bcs.s L16
 bra.w L1
 rts
;  code: 378 + asm() bytes   stack: 0 bytes
 ?end
_delay:
 NOP
 rts
;  code: 2 + asm() bytes   stack: 0 bytes
 ?end
编译器是mentor graphics的编译器.汇编程序只是原文件的一部分,从汇编程序看,好像也是正确,可就是运行的时候,运行到子程序时就停止.
求大侠指教.
[此贴子已经被作者于2005-12-30 16:00:52编辑过]
是不是超出地址范围了?
海纳百川  有容乃大
没有,这里各寄存器的定义的地址没有超出范围的,范围是0xfff000-0xffffff .编译生成的汇编文件里语句
"" jsr _delay ""  ,
是跳转到子程序,jsr的作用是跳转到子程序,并且pc=pc+<disp>,也就是把跳转后的地址赋给程序计数器pc,
但是我发现程序不能继续执行的原因好像是根本没有跳转到子程序.子程序根本没有执行,这会是什么原因呢?
[此贴子已经被作者于2006-1-4 15:08:22编辑过]
自己顶一下
