我有个奇怪的问题,我对McASP配置好了,结果始终是不能出来接收中断,代码如下: /* Configure MCASP. */ MCASP_ConfigGbl MyMCASPcfgGbl = { 0x00000000, /* PFUNC - All pins as McASP */ 0x00000080, /* PDIR - XMT DATA output, rest are inputs */ 0x00000000, /* DITCTL - DIT mode disable */ 0x00000000, /* DLBCTL - Loopback disabled */ 0x00000000 /* AMUTE - Never drive AMUTE */ };
//Set receive registers. MCASP_ConfigRcv MyMCASPcfgRcv = { /* RMASK */ 0xffffffff, /* RMASK - Use all 32 bits */ 0x000180f8, /* RFMT - MSB first, 32-bit slots, CPU bus, 0 bit delay */ 0x00000000, /* AFSRCTL - burst, single bit frame sync, ext FS */ 0x00000080, /* ACLKRCTL - Sample on rising CLK, divide by 1, ext CLK */ 0x00000000, /* AHCLKRCTL - External HCLK */ 0x00000001, /* RTDM - Slots 0-31 are active */ 0x00000020, /* RINTCTL - Reccive interrupt */ 0x00000000 /* RCLKCHK - Not used */ }; //Set serial control. MCASP_ConfigSrctl MyMCASPcfgSrctl = { 0x00000000, /* SRCTL0 - Inactive */ 0x00000000, /* SRCTL1 - Inactive */ 0x00000000, /* SRCTL2 - Inactive */ 0x00000000, /* SRCTL3 - Inactive */ 0x00000000, /* SRCTL4 - Inactive */ 0x00000000, /* SRCTL5 - Inactive */ 0x0000000E, /* SRCTL6 - Receive, active high */ 0x0000000D /* SRCTL7 - Transmit, active high */ };
//Set transmit registers. MCASP_ConfigXmt MyMCASPcfgXmt = { /* XMASK */ 0xffffffff, /* XMASK - Use all 32 bits */ 0x000180f8, /* XFMT - MSB first, 32-bit slots, CPU bus, 0 bit delay */ 0x00000000, /* AFSXCTL - burst, single bit frame sync, ext FS */ 0x000000c0, /* ACLKXCTL - Sample on falling CLK, divide by 1, ext CLK */ 0x00000000, /* AHCLKXCTL - External HCLK */ 0x00000001, /* XTDM - Slots 0-31 are active */ 0x00000000, /* XINTCTL - No interrupts */ 0x00000000 /* XCLKCHK - Not used */ }; MCASP_Config MyMCASPConfig = { &MyMCASPcfgGbl, &MyMCASPcfgRcv, &MyMCASPcfgXmt, &MyMCASPcfgSrctl, }; /********************************************************************************\ \*DEC6713_AIC23_OpenCodec() -Open the codec AIC23. \* Configure AXR1[7] as transmit port and AXR1[6] as \* receive port. \*Parameters: \* \* \*Return: \********************************************************************************/ MCASP_Handle DEC6713_AIC23_OpenCodec() { MCASP_Handle DEC6713_AIC23_DATAHANDLE; Uint32 gblctl;
DEC6713_AIC23_DATAHANDLE = MCASP_open(MCASP_DEV1,MCASP_OPEN_RESET);
/* Reset MCASP to default values by setting GBLCTL = 0.*/ MCASP_reset(DEC6713_AIC23_DATAHANDLE);
MCASP_config(DEC6713_AIC23_DATAHANDLE,&MyMCASPConfig);
/* Clear transmit and receive status ,清除发送与接收状态*/ MCASP_RSETH(DEC6713_AIC23_DATAHANDLE,XSTAT,0xFFFF); MCASP_RSETH(DEC6713_AIC23_DATAHANDLE,RSTAT,0xFFFF);
MCASP_RSETH(DEC6713_AIC23_DATAHANDLE, RINTCTL, 0x00000020); EDMA_Init(); startEdma(); gblctl = 0; MCASP_RSETH(DEC6713_AIC23_DATAHANDLE, GBLCTL, gblctl); gblctl = 0x404; /*使能发送与接收的串行寄存器*/ MCASP_RSETH(DEC6713_AIC23_DATAHANDLE, GBLCTL, gblctl);
/* Enable transmit/receive state machines */ MCASP_RSETH(DEC6713_AIC23_DATAHANDLE, RBUF6, 0); MCASP_RSETH(DEC6713_AIC23_DATAHANDLE, XBUF7, 0); gblctl = 0x0c0c; MCASP_RSETH(DEC6713_AIC23_DATAHANDLE, GBLCTL, gblctl);
return(DEC6713_AIC23_DATAHANDLE); } 望大侠帮忙解决!
