The parallel capacitance (平行电容?)for a given sample can be calculated bydividing the measured series capacitance (串联电容?)by the sum of the dissipation factor squared and 1: Cp = Cs / (1+ Df ^2)
请问什么是parallel capacitance 和series capacitance的定义.
他们的区别在哪呢?
另外介质损耗因数这个量一般如何理解以及测量?
