我的NIOS的建立和NIOS/IDE中的存储器的设置与Atlera的文档介绍的一样,在Build all的时候也能通过,但是就是不能在ISS中仿真调试,说是不能装载,怎么回事?程序如下 #include <stdio.h> #include <unistd.h> #include <string.h> #include "system.h" #include "altera_avalon_timer.h" #include "altera_avalon_timer_regs.h" #include "alt_types.h" #include "sys/alt_irq.h" alt_u8 led=0; alt_u16 cnter=0; alt_u8 timer1_ok=0; static void timer1_init() { IOWR(SYS_CLK_TIMER_BASE,0,0); IOWR(SYS_CLK_TIMER_BASE,ALTERA_AVALON_TIMER_CONTROL_REG,0x0B);//continual count IOWR(SYS_CLK_TIMER_BASE, ALTERA_AVALON_TIMER_PERIODL_REG, 0x93E0); IOWR(SYS_CLK_TIMER_BASE, 3, 0x04); IOWR(SYS_CLK_TIMER_BASE, 1, ALTERA_AVALON_TIMER_CONTROL_CONT_MSK); } void timer1_isr(int context) { IOWR(SYS_CLK_TIMER_BASE, 0, ALTERA_AVALON_TIMER_STATUS_TO_OFST); IOWR(SYS_CLK_TIMER_BASE, ALTERA_AVALON_TIMER_PERIODL_REG, 0x93E0); IOWR(SYS_CLK_TIMER_BASE, 3, 0x04); timer1_ok=1; } void main() { int context=0; alt_irq_register(SYS_CLK_TIMER_IRQ,SYS_CLK_TIMER_BASE,timer1_isr); timer1_init(); while(1) { if(timer1_ok) { timer1_ok=0; cnter++; if(cnter==20) { cnter=0; led^=0xFF; IOWR(LED_PIO_BASE, 0, led); } } } } Build的结果如下:../resource.c:55: warning: passing arg 2 of `alt_irq_register' makes pointer from integer without a cast ../resource.c:55: warning: passing arg 3 of `alt_irq_register' from incompatible pointer type ../resource.c:54: warning: unused variable `context' ../resource.c:77:51: warning: no newline at end of file Info: (test.elf) 33 KBytes program size (code + initialized data). Info: 16350 KBytes free for stack + heap. Post-processing to create ext_flash.flash Hardware simulation is not enabled for the target SOPC Builder system. Skipping creation of hardware simulation model contents and simulation symbol files. (Note: This does not affect the instruction set simulator.) Build completed
