我的8013不能独立引导程序
我的8013不能独立引导程序
Problem #1: I cannot get the DSP to boot up properly
> in standalone
> mode, when disconnected from the PC. I use the C+ASM
> stationery. The
> startup code which copies variables from FLASH to
> RAM at startup seems
> to work properly. I program the DSP, disconnect the
> demo board from
> the JTAG programmer, power down, power up again. The
> DSP rarely boots
> up succesfully (this is very strange, it would be
> more straightforward
> if it *never* booted up...)
zhz2112
是CodeWarrior Stationery 的 MC56F801x_init.asm 文件个bug.所以用PE的Stationery产生Project 总是正确的
