ARM - STM32 使用11.0592MHz晶振 (3)
- void USART_Init(USART_TypeDef* USARTx, USART_InitTypeDef* USART_InitStruct)
- uint32_t tmpreg = 0x00, apbclock = 0x00;
- uint32_t integerdivider = 0x00;
- uint32_t fractionaldivider = 0x00;
- uint32_t usartxbase = 0;
- RCC_ClocksTypeDef RCC_ClocksStatus;
- /* Check the parameters */
- assert_param(IS_USART_ALL_PERIPH(USARTx));
- assert_param(IS_USART_BAUDRATE(USART_InitStruct->USART_BaudRate));
- assert_param(IS_USART_WORD_LENGTH(USART_InitStruct->USART_WordLength));
- assert_param(IS_USART_STOPBITS(USART_InitStruct->USART_StopBits));
- assert_param(IS_USART_PARITY(USART_InitStruct->USART_Parity));
- assert_param(IS_USART_MODE(USART_InitStruct->USART_Mode));
- assert_param(IS_USART_HARDWARE_FLOW_CONTROL(USART_InitStruct->USART_HardwareFlowControl));
- /* The hardware flow control is available only for USART1, USART2 and USART3 */
- if (USART_InitStruct->USART_HardwareFlowControl != USART_HardwareFlowControl_None)
- assert_param(IS_USART_123_PERIPH(USARTx));
- usartxbase = (uint32_t)USARTx;
- /*---------------------------- USART CR2 Configuration -----------------------*/
- tmpreg = USARTx->CR2;
- /* Clear STOP[13:12] bits */
- tmpreg &= CR2_STOP_CLEAR_Mask;
- /* Configure the USART Stop Bits, Clock, CPOL, CPHA and LastBit ------------*/
- /* Set STOP[13:12] bits according to USART_StopBits value */
- tmpreg |= (uint32_t)USART_InitStruct->USART_StopBits;
- /* Write to USART CR2 */
- USARTx->CR2 = (uint16_t)tmpreg;
- /*---------------------------- USART CR1 Configuration -----------------------*/
- tmpreg = USARTx->CR1;
- /* Clear M, PCE, PS, TE and RE bits */
- tmpreg &= CR1_CLEAR_Mask;
- /* Configure the USART Word Length, Parity and mode ----------------------- */
- /* Set the M bits according to USART_WordLength value */
- /* Set PCE and PS bits according to USART_Parity value */
- /* Set TE and RE bits according to USART_Mode value */
- tmpreg |= (uint32_t)USART_InitStruct->USART_WordLength | USART_InitStruct->USART_Parity |
- USART_InitStruct->USART_Mode;
- /* Write to USART CR1 */
- USARTx->CR1 = (uint16_t)tmpreg;
- /*---------------------------- USART CR3 Configuration -----------------------*/
- tmpreg = USARTx->CR3;
- /* Clear CTSE and RTSE bits */
- tmpreg &= CR3_CLEAR_Mask;
- /* Configure the USART HFC -------------------------------------------------*/
- /* Set CTSE and RTSE bits according to USART_HardwareFlowControl value */
- tmpreg |= USART_InitStruct->USART_HardwareFlowControl;
- /* Write to USART CR3 */
- USARTx->CR3 = (uint16_t)tmpreg;
- /*---------------------------- USART BRR Configuration -----------------------*/
- /* Configure the USART Baud Rate -------------------------------------------*/
- RCC_GetClocksFreq(&RCC_ClocksStatus);
- if (usartxbase == USART1_BASE)
- apbclock = RCC_ClocksStatus.PCLK2_Frequency;
- else
- <span style="color:#ff0000;"> apbclock = RCC_ClocksStatus.PCLK1_Frequency;</span>
- /* Determine the integer part */
- if ((USARTx->CR1 & CR1_OVER8_Set) != 0)
- /* Integer part computing in case Oversampling mode is 8 Samples */
- integerdivider = ((25 * apbclock) / (2 * (USART_InitStruct->USART_BaudRate)));
- else
/* if ((USARTx->CR1 & CR1_OVER8_Set) == 0) */
- /* Integer part computing in case Oversampling mode is 16 Samples */
- <span style="color:#ff0000;"> integerdivider = ((25 * apbclock) / (4 * (USART_InitStruct->USART_BaudRate))); </span><span style="color:#3366ff;">//apbclock=0xA8C000=11059200 </span>
- <span style="color:#ff0000;"> tmpreg = (integerdivider / 100) << 4; </span><span style="color:#3333ff;">// 得到integerdivider</span><span style="color: rgb(255, 0, 0); "> </span><span style="color:#3333ff;">
- </span>
- /* Determine the fractional part */
- <span style="color:#ff0000;"> fractionaldivider = integerdivider - (100 * (tmpreg >> 4)); </span><span style="color:#3333ff;">//得到fractionaldivider</span><span style="color: rgb(255, 0, 0); "> </span><span style="color:#ff0000;">
- </span>
- /* Implement the fractional part in the register */
- tmpreg |= ((((fractionaldivider * 8) + 50) / 100)) & ((uint8_t)0x07);
- else
- <span style="color:#ff0000;"> tmpreg |= ((((fractionaldivider * 16) + 50) / 100)) & ((uint8_t)0x0F);</span>
- /* Write to USART BRR */
- USARTx->BRR = (uint16_t)tmpreg;
小数波特率发送和接收由一共用的波特率发生器驱动,当发送器和接收器的使能位分别(TE和RE)置位时,分别为其产生时钟。接收器和发送器的波特率应设置成相同。
Tx / Rx 波特率 = PCLKx / (16 * USARTDIV)PCLKx可以是APB1的时钟PCLK1(用于USART1),也可以是APB2的时钟PCLK2(用于USART2、3、4、5) 。
USARTDIV = DIV_Maintissa[11:0] + DIV_Fraction[3:0] / 16USARTDIV是一个无符号的定点数,转换成对应的二进制小数后,整数部分存放在USART_BRR寄存器中的DIV_Maintissa[11:0],小数部分存放在USART_BRR寄存器中的DIV_Fraction[3:0]。
注:在写入USART_BRR之后,波特率计数器会被波特率寄存器的新值替换。因此,不要在通信进行中改变波特率寄存器的数值。 |
