ad0809转换调试2天没有结果大家帮忙仿真可以的,但是下载后fpga控制adc0809的信号ale和start都不能产生,是状态机的问题还是其他什么问题。大家帮忙 ADC0809 工作时序分析 ADC0809 的工作时序START是转换启动信号,高电平有效; ALE是3 位通道选择地址(ADDC、ADDB、ADDA) 信号的锁存信号. 当模拟量送至某一输入端,由3 位地址信号选择,而地址信号由ALE锁存; EOC是转换情况状态信号,当启动转换约100μs后,EOC产生一个负脉冲,以示转换结束;在EOC的上升沿后,若使输出使能信号OE为高电平,则控制 打开三态缓冲器,把转换好的8 位数据结果输送至数据总线.至此ADC0809的一次转换结束了.
状态机的程序 library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity adc0809 is port( reset : in std_logic; clk : in std_logic; eoc : in std_logic; D : in std_logic_vector(7 downto 0); lock : out std_logic; ale : out std_logic; start : out std_logic; oe : out std_logic; -- st : out integer range 7 downto 0; adda : out std_logic; addb : out std_logic; addc : out std_logic; data : out std_logic_vector(7 downto 0) ); end entity; architecture func of adc0809 is type state_type is (st0, st1, st2, st3, st4, st5, st6); signal current_state,next_state : state_type:=st0; signal lock1 : std_logic; signal reg : std_logic_vector(7 downto 0); begin adda<='1'; lock<=lock1; process (current_state, eoc) begin case current_state is when st0=> ale<='0'; start<='0'; oe<='0'; lock1<='0'; next_state<=st1; when st1=> ale<='1'; start<='0'; oe<='0'; lock1<='0'; next_state<=st2; when st2=> ale<='0'; start<='1'; oe<='0'; lock1<='0'; next_state<=st3; when st3=> ale<='0'; start<='0'; oe<='0'; lock1<='0'; if(eoc='0')then next_state<=st4; else next_state<=st3; end if; when st4=> ale<='0'; start<='0'; oe<='0'; lock1<='0'; if(eoc='1')then next_state<=st5; else next_state<=st4; end if; when st5=> ale<='0'; start<='0'; oe<='1'; lock1<='0'; next_state<=st6; when st6=> ale<='0'; start<='0'; oe<='1'; lock1<='1'; next_state<=st0; when others=> next_state<=st0; end case; end process;
process (clk,reset) begin if(reset='1')then current_state<=st0; elsif (clk'event and clk='1') then current_state<=next_state; end if; end process;
process (lock1) begin if (lock1='1' and lock1'event) then reg<=D; end if; end process; data<=reg; end func; |
