COMMAND窗口里显示这些,程序无法成功下载了,救命啊~~~~
Reset command file correctly executed.
FP: FLASH parameters loaded for MC9S12XF512_V1(NVMIF2 rev 3,3,4,6) from D:\Program Files\Freescale\CodeWarrior for HCS12 V4.7\prog\FPP\mcu02E4.fpp
<Timeout> (> 2000 ms)
Program counter: 0x00000063
Block Module Name Address Range Status
0 FLASH_4000 FF00 - 11DFF Programmed - Unselected
1 FLASH_8000 FF00 - 11DFF Programmed - Unselected
2 FLASH_C000 FF00 - 10DFF Programmed - Unselected
3 ALL_PPAGES FFFFFF -1FFFFFD Skipped - Unselected
FP: The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_8000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
FP: Call of a command not implemented!
Please modify "flags" in ALL_PPAGES module INFO applet.
0 FLASH_4000 FFFFFF -1FFFFFD Skipped - Selected
1 FLASH_8000 FFFFFF -1FFFFFD Skipped - Selected
2 FLASH_C000 FFFFFF -1FFFFFD Skipped - Selected
3 ALL_PPAGES FFFFFF -1FFFFFD Skipped - Selected
executing .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
Vppon command file correctly executed.
FP: The ERASE command is not performed for the FLASH_4000 flash module (AEFSKIPERASING) => Skipped.
FP: The ERASE command is not performed for the FLASH_8000 flash module (AEFSKIPERASING) => Skipped.
FP: The ERASE command is not performed for the FLASH_C000 flash module (AEFSKIPERASING) => Skipped.
FP: The ERASE command is not performed for the ALL_PPAGES flash module (AEFSKIPERASING) => Skipped.
executing .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd |
