linux实战(六)----获取备份时间----实例解析(3)
脚本运用当前时间
修改后脚本为:
#!/bin/bash
function GetDiskSpc
if [ $# -ne 1 ]
then
return 1
fi
Folder="$1$"
DiskSpace=`df -k |grep $Folder |awk '{print $5}' |awk -F% '{print $1}'`
echo $DiskSpace
function CheckDiskSpc
DiskSpace=`GetDiskSpc $1`
echo "The system $Folder disk space is $DiskSpace%"
echo "The system $Folder disk space is $DiskSpace%" >> space.txt
if [ $DiskSpace -gt 90 ]
then
echo "The usage of system disk($Folder) is larger than 90%"
echo "The usage of system disk($Folder) is larger than 90%" >> space.txt
else
echo "The usage of system disk($Folder) is normal"
echo "The usage of system disk($Folder) is normal" >> space.txt
fi
CheckDiskSpc /boot
time=`date +%F`
tar cvf - /data/shell/space.txt > /data/shell/${time}space.tar
rm space.txt |
